Programmable Devices
21615 Discussions
Problem when download FPGA SRAM OBJECTIVE FILE.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8003
when use Quartus II software and select Tools > Programmer to download .sof instance file .
coming:
Info (209060): Started Programmer operation at Wed Nov 06 17:58:42 2013
Error (209031): Device chain in Chain Description File does not match physical device chain -- expected 1 device(s) but found 2 device(s).
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Wed Nov 06 17:58:42 2013
the device is auto detected .
where is the problem?
--- Quote Start ---
coming:
--- Quote End ---
As I see you are using Arrow SocKIT dev. board.
- Configure FPGA board properly ! (SOCVHPS is missed from your actually detected chain)
- Reset FPGA (try warm, hard, and FPGA reset)
- Hardware Setup -> CV_SOCKIT
- Auto detect chain
- Change file -> browse for .sof (which contains the same FPGA device as 5CSXFC6D6)
- Finally, Program FPGA
alternatively, try
Quartus -> Tools -> JTAG chain debugger -> Test JTAG chain
Altera help:
http://quartushelp.altera.com/13.1/mergedprojects/msgs/msgs/epgme_chain_length_mismatch.htm
Zs.V.
--- Quote Start ---
- Auto detect chain
alternatively, try
Altera help:
Zs.V.
--- Quote End ---
thank you so much!
i set jtag clock speed at 16M, the follow:
- Auto detect chain
it works.
