21615 Discussions
Problem with Dsp builder
Hi:
I have a problem with Altera Dsp Builder; I tried to run a demo but when I opened the mdl file (on MATLAB simulink) a lot of blocks appeared with the label "bad link" and obviously the simulation failed.
Would someone please tell me what can i do?
PD: I have the MATLAB 7.2 version
Have you run all the install commands for DSp builder in Matlab? They are described in the release notes doc.
http://www.altera.com/literature/rn/rn_dsp_builder.pdf
Hi Luis,
I've had the same problem when trying to load old examples dowloaded from altera web site. I suppose it was becasuse some of those projects were developped with older DSPbuilder version. Try to load whith any error the examples from your installed DspBuilder.
