Design a 5-bit up/down counter with synchronous counting, asynchronous preset and asynchronous master reset. Write a VHDL design description of the counter based on the following criteria:
a) The counter increments or decrements on a positive clock edge only if its active-HIGH enable (EN) is asserted. b) The master reset (MR) is an active-HIGH input that resets the counter to 00000 state. c) The counter can be preset to the logic levels present on the parallel data inputs (P4P3P2P1P0) by activating the parallel load input (file:///C:/DOCUME%7E1/Arpah/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif ) from HIGH to LOW. d) The count outputs are Q4Q3Q2Q1Q0 where Q0 is the LSB and Q3 is the MSB. e) A LOW at UP_DW input causes the counter to decrement. For up counting, a HIGH at the UP_DW input. This is the our programme: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity d1 is port (clk, MR, EN,UP_DW, p_load: in std_logic; p : in std_logic_vector (4 downto 0); q : out std_logic_vector (4 downto 0)); end d1; architecture flow of d1 is signal count_sig: unsigned (4 downto 0); begin process (clk, MR) begin if (MR='1') then count_sig <= "00000"; elsif (p_load='0') then case p is when "00000"=>count_sig<="00000"; when "00001"=>count_sig<="00001"; when "00010"=>count_sig<="00010"; when "00011"=>count_sig<="00011"; when "00100"=>count_sig<="00100"; when "00101"=>count_sig<="00101"; when "00110"=>count_sig<="00110"; when "00111"=>count_sig<="00111"; when "01000"=>count_sig<="01000"; when "01001"=>count_sig<="01001"; when "01010"=>count_sig<="01010"; when "01011"=>count_sig<="01011"; when "01100"=>count_sig<="01100"; when "01101"=>count_sig<="01101"; when "01110"=>count_sig<="01110"; when "01111"=>count_sig<="01111"; when "10000"=>count_sig<="10000"; when "10001"=>count_sig<="10001"; when "10010"=>count_sig<="10010"; when "10011"=>count_sig<="10011"; when "10100"=>count_sig<="10100"; when "10101"=>count_sig<="10101"; when "10110"=>count_sig<="10110"; when "10111"=>count_sig<="10111"; when "11000"=>count_sig<="11000"; when "11001"=>count_sig<="11001"; when "11010"=>count_sig<="11010"; when "11011"=>count_sig<="11011"; when "11100"=>count_sig<="11100"; when "11101"=>count_sig<="11101"; when "11110"=>count_sig<="11110"; when "11111"=>count_sig<="11111"; when others=>count_sig<=count_sig; end case; elsif (p_load='1') then count_sig<=count_sig; if (EN='0') then count_sig<=count_sig; elsif rising_edge(clk) then case UP_DW is when '1'=>count_sig<=count_sig +1; when '0'=>count_sig<=count_sig -1; end case; end if; end if; end process; q<= std_logic_vector (count_sig); end flow; May i know why my waveform is not the same as the expected answer. ThanksLink Copied
Is it possible that u can't place a rising_edge in a if - elsif structure.
Re-write it as:if risin_edge ... then
if reset then
count_value <= 0;
elsif load then
count_value <= load_value
elsif count_up then
count_value <= count_value + 1;
elsif count_dwn then
count_value <= count_value -1;
end if;
end if;
i didn't read the whole text to forfill ur teachers question :)
I think it's possible to make it like
if reset
elsif load
else
if rising_edge
end if;
end if;
Now put count up and down under the rising edge to make reset and load async and up and down sync. But rising edge in if - else structure is not done ;-) cauze inpout is a clock you only can use it like: if rising_edge then end if; and not like if rising_edge then else end if;
your input P is 7, so the q value takes 7 as the active low load signal loads it.
There are many redundant lines in your code. you never need to assign count_sig to itself. Here is a much tidier version of your code. I have removed the asynchronous enable because you want to use it synchronously:
begin
process (clk, MR, p_load, p)
begin
if (MR='1') then
count_sig <= unsigned(p);
if EN = '1' then
case UP_DW is
when others => count_sig <= "XXXXX";
end case;
end if;
end if;
end process;
end flow;
--- Quote Start --- Is it possible that u can't place a rising_edge in a if - elsif structure. --- Quote End --- Yes, elsif rising_edge(clock) is fine, else how would you have asynchronous resets or loads?
--- Quote Start --- Yes, elsif rising_edge(clock) is fine, else how would you have asynchronous resets or loads? --- Quote End --- True. My second post is the same like "elsif rising_edge" but i never write it like that.
--- Quote Start --- your input P is 7, so the q value takes 7 as the active low load signal loads it. There are many redundant lines in your code. you never need to assign count_sig to itself. Here is a much tidier version of your code. I have removed the asynchronous enable because you want to use it synchronously:
begin
begin
if (MR='1') then
if EN = '1' then
case UP_DW is
end case;
end if;
end if;
end process;
end flow;
--- Quote End --- I just tried this code just now. However it still can't give the graph of the expected outcome.
The problem isnt with the code. I just tidied up your version. The problem is that you load 7 onto count_sig at the start of the simulation. P_load has preference over the clock. The problem lies with your testbench.
Topic Options
