21611 Discussions
Problem with a 5-bit counter programme
Design a 5-bit up/down counter with synchronous counting, asynchronous preset and asynchronous master reset. Write a VHDL design description of the counter based on the following criteria:
a) The counter increments or decrements on a positive clock edge only if its active-HIGH enable (EN) is asserted.
b) The master reset (MR) is an active-HIGH input that resets the counter to 00000 state.
c) The counter can be preset to the logic levels present on the parallel data inputs (P4P3P2P1P0) by activating the parallel load input (file:///C:/DOCUME%7E1/Arpah/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif ) from HIGH to LOW.
d) The count outputs are Q4Q3Q2Q1Q0 where Q0 is the LSB and Q3 is the MSB.
e) A LOW at UP_DW input causes the counter to decrement. For up counting, a HIGH at the UP_DW input.
This is the our programme:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity d1 is
port (clk, MR, EN,UP_DW, p_load: in std_logic;
p : in std_logic_vector (4 downto 0);
q : out std_logic_vector (4 downto 0));
end d1;
architecture flow of d1 is
signal count_sig: unsigned (4 downto 0);
begin
process (clk, MR)
begin
if (MR='1') then
count_sig <= "00000";
elsif (p_load='0') then
case p is
when "00000"=>count_sig<="00000";
when "00001"=>count_sig<="00001";
when "00010"=>count_sig<="00010";
when "00011"=>count_sig<="00011";
when "00100"=>count_sig<="00100";
when "00101"=>count_sig<="00101";
when "00110"=>count_sig<="00110";
when "00111"=>count_sig<="00111";
when "01000"=>count_sig<="01000";
when "01001"=>count_sig<="01001";
when "01010"=>count_sig<="01010";
when "01011"=>count_sig<="01011";
when "01100"=>count_sig<="01100";
when "01101"=>count_sig<="01101";
when "01110"=>count_sig<="01110";
when "01111"=>count_sig<="01111";
when "10000"=>count_sig<="10000";
when "10001"=>count_sig<="10001";
when "10010"=>count_sig<="10010";
when "10011"=>count_sig<="10011";
when "10100"=>count_sig<="10100";
when "10101"=>count_sig<="10101";
when "10110"=>count_sig<="10110";
when "10111"=>count_sig<="10111";
when "11000"=>count_sig<="11000";
when "11001"=>count_sig<="11001";
when "11010"=>count_sig<="11010";
when "11011"=>count_sig<="11011";
when "11100"=>count_sig<="11100";
when "11101"=>count_sig<="11101";
when "11110"=>count_sig<="11110";
when "11111"=>count_sig<="11111";
when others=>count_sig<=count_sig;
end case;
elsif (p_load='1') then
if (EN='0') then
elsif rising_edge(clk) then
case UP_DW is
when '1'=>count_sig<=count_sig +1;
when '0'=>count_sig<=count_sig -1;
end case;
end if;
end if;
end process;
q<= std_logic_vector (count_sig);
end flow;
May i know why my waveform is not the same as the expected answer. Thanks
Is it possible that u can't place a rising_edge in a if - elsif structure.
Re-write it as:
if risin_edge ... then if reset then count_value <= 0; elsif load then count_value <= load_value elsif count_up then count_value <= count_value + 1; elsif count_dwn then count_value <= count_value -1; end if; end if;
i didn't read the whole text to forfill ur teachers question :)
I think it's possible to make it like
if reset elsif load else if rising_edge end if; end if;
Now put count up and down under the rising edge
to make reset and load async and up and down sync.
But rising edge in if - else structure is not done ;-)
cauze inpout is a clock
you only can use it like:
if rising_edge then
end if;
and not like
if rising_edge then
else
end if;
your input P is 7, so the q value takes 7 as the active low load signal loads it.
There are many redundant lines in your code. you never need to assign count_sig to itself.
Here is a much tidier version of your code. I have removed the asynchronous enable because you want to use it synchronously:
begin process (clk, MR, p_load, p) begin if (MR='1') then count_sig <= "00000"; elsif (p_load='0') then count_sig <= unsigned(p); elsif rising_edge(clk) then if EN = '1' then case UP_DW is when '1'=>count_sig<=count_sig +1; when '0'=>count_sig<=count_sig -1; when others => count_sig <= "XXXXX"; end case; end if; end if; end process; q<= std_logic_vector (count_sig); end flow;
--- Quote Start ---
--- Quote End ---
Yes, elsif rising_edge(clock) is fine, else how would you have asynchronous resets or loads?
--- Quote Start ---
--- Quote End ---
True. My second post is the same like "elsif rising_edge" but i never write it like that.
--- Quote Start ---
--- Quote End ---
I just tried this code just now. However it still can't give the graph of the expected outcome.
The problem isnt with the code. I just tidied up your version. The problem is that you load 7 onto count_sig at the start of the simulation. P_load has preference over the clock. The problem lies with your testbench.
