21602 Discussions
Problem with a simple bi-direcional counter simulation
Hello this is my code
module count_moda # (parameter modulus = 100) ( input clk, aclr_n, updown, output reg q ); initial q = 0; always @(posedge clk, negedge aclr_n) begin if (!aclr_n) q <= 0; else begin q <= q + (updown? 1'b1 : -1'b1); if (q == modulus-1) q <= 8'd0; // if (q == 0) // q <= modulus -1; end end endmodule
The way it is right now it restarts when 99 is reached, then it starts to count up untill 10 when my updown signal goes to 0 and it starts decremetating to 9, 8 etc.. untill it goes to a negative value!
But i want to go back to 99 when i reach 0 in the decrematating mode, don't know how to solve it
If i uncomment the second if my result is always 0 or 99.
You can't perform the overflow/underflow operation correctly without using the updown input, it seems so obvious...
> if (q == modulus-1) > q <= 8'd0;
this script should be
if( updoun )
begin
if( q == (modulus-1) )
q <= 8'h0;
end
else
begin
if( q == 8'h0 )
q <= (modulus-1) ; end
I think this is obvious too.
you haven't written reset logic for negative direction.
