21608 Discussions
Problem with dynamic PLL reconfiguration
I am working on a project which involves dynamically configuring PLL to different frequencies.
I have written a VHDL code for my requirement, however I am facing some circumstances in simulation which I am not able to comprehend.
When I give a reset to the PLL I expect clock to be 0 and locked signal to be 0 immediately.
However I find that lock signal doesnt reset at all.
This would affect my design as out of range clocks might get into my logic and system might just crash.
I have attached simulation snapshot.
Please help.
What does resetn_sig refer to in your design? Seems like this signal is not valid in the simulation.
Hi Nic,
In the snapshot above rst_usr is the signal that is input as reset to PLL.
For better clarity I have attached another snapshot with pll rst, lock and pll output clock coloured in yellow.
Note that lock is not getting low even after reset is asserted.
