21615 Discussions
Problem with signing spins on Cylone GX IV
I got this error when signing spin on Cyclone GX IV:
Error: Pin C1 does not support I/O standard 1.5 V for TDm Error: Pin C2 does not support I/O standard 1.5 V for TDp
Can anyone help me solve this issue? :confused:
I am not sure, but aren't these transceiver pins? If yes, then You can't choose LVTTL, 3.3V, 2.5V, etc voltages for those pins...
I thought the voltage for transceiver pins would be 1.5-V PCML. But when I changed the I/O Standard to 1.5-V PCML, it created a differential pin, and I don't know what it is for. :confused:
Well that's correct, the transceiver uses differential signaling.
This is the error I got:
Error: Differential I/O output pin TDp is assigned to a non differential location C2. However, it must be assigned to a differential output location Error: Differential I/O output pin TDp(n) is assigned to a non differential location C1. However, it must be assigned to a differential output location
How to solve this issue? :)
When You select pin as differential, Pin Planner automatically creates positive and negative pins, so assign a signal to proper pins.
Can you tell me the name of the differential pins for transceiver on Cyclone GX IV? :)
which device exactly?
--- Quote Start ---
--- Quote End ---
EP4CGX15BF14C8 :p
C1, C2 for TX1
E1, E2 for RX1
G1, G2 for TX0
J1, J2 for RX0
I got this error:
Error: Differential I/O output pin TDp is assigned to a non differential location G2. However, it must be assigned to a differential output location Error: Differential I/O output pin TDp(n) is assigned to a non differential location G1. However, it must be assigned to a differential output location
:p
Add a screenshot of pin planner
Why did You assign TDp to negative pair node?
--- Quote Start ---
--- Quote End ---
Can you tell me how to assign TDp to positive pair node? I'm just a newbie. :D
Delete both assignments and assign positive to positive, so negative will be assigned automatically.
I can't imagine how to do. I added all screenshots of the steps I did in Pin Planner. Please tell me which step I did wrong.
Step 1
http://img851.imageshack.us/img851/2745/pinplanner1.png
Step 2
http://img830.imageshack.us/img830/3834/pinplanner2.png
Step 3
http://img545.imageshack.us/img545/7495/pinplanner.png
Can anyone help me solve this issue? I can attach the source file if you want. :(
