21615 Discussions
Problem with state machine (AHDL)
Hi all,
i'm a newbie in ADHL programming and have a problem with the code of the state machine below. I tested it on my CPLD-Board (MAX II).
The machine works well when the signal "relais" is in LOW-state. When "relais" is on HIGH-state, i think the state machine doesnt jump in the "ignore" state.
I cant see the bug of the code.
SUBDESIGN ignore_signal ( comp_in, relais, reset, CPLD_CLK : INPUT; comp_out : OUTPUT; ) VARIABLE ignore_machine : MACHINE WITH STATES(init, ignore, high, ignored); counter : DFF; BEGIN counter.clk = CPLD_CLK; CASE ignore_machine IS WHEN init => comp_out = GND; IF relais THEN counter = 0; ignore_machine = ignore; ELSIF comp_in THEN comp_out = VCC; ignore_machine = high; ELSE ignore_machine = init; END IF; WHEN ignore => comp_out = GND; counter = counter+1; IF counter >= 1200000 THEN comp_out=VCC; IF comp_in THEN comp_out = VCC; ignore_machine = high; ELSE comp_out = GND; ignore_machine = ignored; END IF; ELSE ignore_machine = ignore; END IF; WHEN high => comp_out = VCC; IF !reset THEN comp_out = GND; ignore_machine = init; ELSE comp_out = VCC; ignore_machine = high; END IF; WHEN ignored => comp_out = GND; IF comp_in THEN comp_out = VCC; ignore_machine = high; ELSIF !relais OR !reset THEN comp_out = GND; ignore_machine = init; ELSE comp_out = GND; ignore_machine = ignored; END IF; END CASE; END;
first of all - AHDL is an old and now unsupported language. I highly suggest you move to a language that you can simulate, like VHDL or Verilog.
Secondly, are comp_in and relais synchronous signals? if not, you may be getting glitches.
And where is the synchronous register for the state machine?
