21615 Discussions
tcl script to modify origin of a region
I need a way of modifying the result of the following line using tcl scripting.
set ORIGIN [get_logiclock -region $region -origin]
The previous line gives the origin of a LogicLock region which I want to modify using arithmetic operations. The return is of the following form
X#_Y# where# are x and y locations
How can I extract those numbers and let's say add 2 to the x coordinate using tcl?
Thank you,
-Adrian
Lookup "regexp". It will be something like:
regexp {^(X)([0-9]+)(_Y)([0-9]+)$} $ORIGIN all x x_coord y y_coord
I would run a few experiments with different ORIGIN values, then the regexp, and then dump it with:
puts "all=$all x=$x, x_coord=$x_coord, y=$y y_coord=$y_coord"
Thank you,
-Adrian
