21615 Discussions
Problem with the installation of the NiosII IDE
I am trying to install the NiosII IDE 8.0 on my PC, but after extracting the install files, while starting the setup, an error occurs.
Error Code: -5004 : 0x80041f42
Error Information:
*C:\Programme\Gemeinsame Dateien\InstallShield\Professional\RunTime\11\50\Intel32\iKernel.dll
>inc\CoCreate.cpp (44)
>SetupDLL\SetupDLL.cpp (1405)
pAPP:Nios II Embedded Design Suite
PVENDOR:Altera Corporation
PGUID:fe92770e-1ead-4004-8aa8-d36866d94394
$11.50.0.42618
@Windows XP Service Pack 3 (2600) BT_OTHER 67.0
I tried to reload the setup, because I thought the file is maybe corrupt, but this does not solve the problem. I orderer a CD from Altera and tried again, but the same message occured.
Quartus II and Modilsim are installed already. I think the Problem is Windows XP Service Pack 3, but I'm not sure about it.
Has somebody an idea about it? Google did not help me until now.
kloocki
--- Quote Start ---
Error Information:
$11.50.0.42618
kloocki
--- Quote End ---
Do you have any spaces in the names of the installation directories? SOPC Builder won't work if you install the packages in a directory say "Program Files" which has spaces in its name.
No, I've no spaces in any path. My install path is:
D:\Altera\81
I still got the problem. But XP Service pack 3 can't be the reason, because I tested the installation on a virtual machine running XP SP3.
It must be a problem with the installshield, I think. Some people at work, also have this problem. :-(
