21602 Discussions
Problems building Preloader
Im following the steps here: http://www.rocketboards.org/foswiki/documentation/gsrdpreloader
After having made some minor changes to the FPGA design. When I run the makefile, I get the following unhelpfull errors:
make CROSS_COMPILE=arm-none-eabi- -C uboot-socfpga socfpga_cyclone5_config
make[1]: Entering directory `/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga'
: invalid option
make[1]: *** [socfpga_cyclone5_config] Error 1
make[1]: Leaving directory `/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga'
make: *** [config] Error 2
Anyone got any ideas?
Probably nothing but maybe check the makefiles & co for mixed unix/windows line endings, linux make gave some strange errors for me with that, before i figured it out. ( I somehow managed to generate such a file and only saw it because the file size of one of the uboot files was different from a working configuration. Generating the BSP on top of an existing file structure also seems to be a bad idea).
Try to do steps as below:
1) Re-compile whole Quartus project.
2) use bsp-editor to create new preloader source code
3) build preloader.
