21615 Discussions
Problems with NANO/ATLAS SOCKIT
in this example controlling LEDS throught AXI from C code,
the project in QUARTUS II in top level ghrd.v shows this "connection" (from qsys export) as:
soc_system u0 (
.pio_led_external_connection_export(LED),
and LED bus deffinition on MODULE at ghrd.v, (assigned to LED pins in PIN PLANNER)
output [7:0] LED,
then if i create this BUS:
output [7:0] DATA1,
and change the line in SOC_SYSTEM:
soc_system u0 (
.pio_led_external_connection_export(DATA1),
Compiler shows like PIN LED[x] is stuck at GND, dowsnt work (BDF schematic file does not affect in the project).
If i put DBF as TOP LEVEL in hierarchy and create a symbol for ghrd.v, then connecting to pins out (like an "Interface" of the original example) like:
http://i.imgur.com/3uiczoc.jpg
y get errors
Error: The auto-constraining script was not able to detect any instance for core < hps_sdram_p0 >
and doesn't work.
How can i use a DBF schematic in a project with SYSTEM_SOC module as shows my_first_hps-fpga example?
