21612 Discussions
Programming non volatile memory of FPGA Devkit - Intel Arria 10 soc devkit
MK_ABQ
New Contributor III
I have an Intel Arria 10 soc devkit (Arria 10 GX devkit - DK-DEV-10AX115S-A)
I have success with programming a basic sof and have seen its behavior. I would now like to program the volatile memory in the devkit so that FPGA can boot up once I power of and power back on.  I am not sure on which options to pursue.
1) Should I use .pof or .flash for this goal?
2) should I program the cpld and flash to achieve this?.
3) There are different modes specified in the user guide ( Active serial, passive serial , jtag mode).
I couldn't get a clear picture from the user guide and not sure which way/mode to follow.
can someone kinda throw some light on this?
NurAiman_M_Intel
May I know is this the userguide that you are referring to?
https://www.intel.com/content/www/us/en/docs/programmable/683269/current/programming-volatile-or-non-volatile.html
Aiman
NurAiman_M_Intel
Is there any update for this case?
Aiman
MK_ABQ
New Contributor III
I was able to program .jic using active serial mode.
SW5 ( MSEL (2:0)) = 010 for Active Serial Fast mode
SW4.2                     = ON to disable Max V from the JTAG chain
SW6.4                     = OFF to load user image from flash.
couldn't figure out .pof solution yet. but this ticket can be closed now.
thanks
FvM
there's a similar thread about .pof programming of this board, however not yet solved. https://community.intel.com/t5/Programmable-Devices/Flash-memory-not-detected-Arria-10-Development-kit/m-p/1534599
Selecting AS configuration works for this board because it has dual configuration flash, PP + AS.
AS configuration may be too slow to get PCIe recognized at power-on, depending on BIOS Features. Therefore PP may be preferred.
I don't have this board and can't tell if MAX V PFL implementation supports .pof programming, it basically should.
You may also want configuration update without USB-Blaster being involved. In this case, flash update has to be implemented in Arria 10, either in HDL logic or soft processor.
NurAiman_M_Intel
Thank you for your response. I will proceed to close this case for now. However, you are always welcome to post a new case in the forum or open an IPS(as you have IPS account) if you need further support.
Aiman
