21615 Discussions
Q:without epcs,why does not start uclinux
ssram,flash,etc WITHOUT EPCS!
quartus only has the avalon_cy7c1380_ssram IP core
No avalon_cy7c1480_ssram IP core!
so
I wanna download the uclinux with loading in cfi_flash(PC28F00AM29EWL, 1Gb)and excuting in the ssram(72Mb,[B],so only 2M is recognized in SOPC or QSYS).
(nios2-linux-2010)
make vendor_hwselect SYSPTF=/home/s4gt.ptf RUNNING hwselect --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: f Version: 7.08100 Selection: 1 --- Please select a device to execute kernel from: (1) descriptor_memory Class: altera_avalon_onchip_memory2 Size: 4096 bytes (2) ext_flash Class: altera_avalon_cfi_flash Size: 134217728 bytes (3) onchip_ram_m9 Class: altera_avalon_onchip_memory2 Size: 1048576 bytes (4) ssram Class: no_legacy_module Size: 2097152 bytes Selection: 4
(4) ssram
-----------Means not recognizing the ssram IP to excute the uclinux correctly!!----------
make linux image ...then nios2-flash-programmer to the FLASH
starting processor at reset vector
nios2-terminal
then there's no response ...
fdsa
(4) ssram
Quartus only has the avalon_cy7c1380_ssram IP core
There's no avalon_cy7c1480_ssram IP core!
