21611 Discussions
Quartus 2 and .LVDS
I have an easy question for one of the experts. I am using Quartus 2 13.1 and trying to program a Terasic DE3. This is the board with the 4 HSTC connectors, connected to the pads that support LVDS. Here's what I did:
In Verilog I instantiate an input that will come in as LVDS, and an output that goes out single ended on a QPIO pin (to be viewed on a logic analyzer) in the top level module top.v
module top (
output qpio,
input top
assign qpio = top;
endmodule
I then select Processing/Start/Start Analysis & Elaboration and then go into the Pin Planner. I set the pin for the input pin "top" to a legitimate differential pin, and set the I/O Standard to LVDS. The Pin Planner automatically inserts the negative pair for that pin also as LVDS, which is what I expect. I also select the pin for "qpio" as 3.3V. So far so good.
When I compile it, it works fine. However, I also want to set the internal resistance to 100 Ohms. So I look in the Pin Planner, and there's a column called "Input Termination", which looks promising, but when I click on it to see what the options are, all I see are things like "Off", "Parallel 50 Ohm with Calibration", then a bunch of "Series 25 Ohms..." options, 40, 50, and 60, but that's it, nothing that says "100 Ohms" or the option "Differential", which is what I had expected. How do I get it to put 100 Ohms across the pair?
Also, is it correct that I do not need to instantiate a differential IO buffer in my Verilog? I'm assuming that is the case, since there is no "n" input to route to it anyway.
You did everything correctly. The available termination options for LVDS input are "differential" or no termination. Differential is 100 ohm.
--- Quote Start ---
--- Quote End ---
Thanks. But how come for some pins I select LVDS as the I/O Standard but the termination options do not include “Dofferential”? They only include the others as detailed above? Under what circumstances does the tool do this?
thanks again!
Can you give an example for which DE3 LVDS pin pair (device type, pin id) it's not possible? The only reason I can think of is that the respective input doesn't provide termination, see Stratix III hardware handbook.
Hi. Sorry for the delay.
The pins that allow "Differential" termination are on I/O Bank 1A, but the pins that do not are on I/O Banks 8B and 8C.
Thanks again!
Device handbook tells you that differential termination is only available on row (left/right) IO banks.
