21595 Discussions
Quartus 2022.4 Interlaken IP generation Problem
emrahener
When I try to generate an Interlaken IP I get the following Error In the Parameter Editor Screen there is no device_revision parameter available in the menu.
Error: Interlakenx16: set_instance_parameter_value: No parameter device_revision
while executing
"set_instance_parameter_value ilk_f_adme device_revision $device_revision"
(procedure "elaborate" line 460)
invoked from within
"elaborate"
skbeh
Hi Emrah
I've tried follow the steps in '1.2 Generating the Design' of the F-tile Interlaken Design Example User Guide below, then generation was successful without error.
I tried with F-tile device AGIB027R31B1E2V.
https://www.intel.com/content/www/us/en/docs/programmable/683069/22-4-6-0-0/generating-the-design.html
Please try again using F-tile device AGIB027R31B1E2V, if you still see the error, please provide your steps to generate the example design that led to this error.
skbeh
Hi
I wish to follow up with you about this case.
Feel free to post a note if you still unable to generate the example design. Thanks.
Soon
