21597 Discussions
Quartus Fitter Crashes (Prime Pro 16.1.0) when compiling for Arria 10 SOC
Just changed some IO bank voltage assingments from 1.5 to 1.8 and now fitter crashes at same point it seems every time, many pins were changed but no idea why this would break it, just found update 1 for 16.1 so i'll try that but any pointers welcome.
Updated to 16.1.1 same erro, stack trace says
Problem Details
Error:
Internal Error: Sub-system: DEV, File: /quartus/ddb/dev/dev_pad_info_body.cpp, Line: 2287
Key not defined in data file: STRING_HPS_FUNCTION_NAME
Stack Trace:
0x4125e: DEV_PAD_BODY::get_string_data + 0x26936 (DDB_DEV)
0xf681: HPS_ATOM_LEGALITY_PLUGIN::assert_hps_pad_location + 0x2b1 (periph_hps)
0x10b40: HPS_ATOM_LEGALITY_PLUGIN::check_atom_that_only_connect_to_io + 0x5a0 (periph_hps)
0x10406: HPS_ATOM_LEGALITY_PLUGIN::check_atom + 0x96 (periph_hps)
0x1578ff: CUT_ATOM_LEGALITY::check_atom + 0x6f (db_cut)
0x13800f: FSAC_NETLIST_CHECK_OP::netlist_is_ok + 0x35f (FITTER_FSAC)
0x3b3f7: FDRGN_PREFIT_NETLIST_CHECK_OP::work + 0x37 (fitter_fdrgn)
0x21a71: FDRGN_EXPERT::check_netlist_legality + 0x81 (fitter_fdrgn)
0x28ae3: FDRGN_EXPERT::place_pre_vpr + 0x173 (fitter_fdrgn)
0x2873a: FDRGN_EXPERT::place + 0x1a (fitter_fdrgn)
0x1439b: fit2_fit_place_auto + 0x20b (comp_fit2)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x3c3a: fit2_fit_place + 0x2fa (comp_fit2)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x12606: qexe_evaluate_tcl_script + 0x376 (comp_qexe)
0x11864: qexe_do_tcl + 0x334 (comp_qexe)
0x16755: qexe_run_tcl_option + 0x585 (comp_qexe)
0x37e33: qcu_run_tcl_option + 0x1003 (comp_qcu)
0x160aa: qexe_run + 0x39a (comp_qexe)
0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
0x2233: qfit2_main + 0x73 (quartus_fit)
0x13328: msg_main_thread + 0x18 (CCL_MSG)
0x14b0e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x15b00: mem_thread_wrapper + 0x70 (ccl_mem)
0x12a11: msg_exe_main + 0xa1 (CCL_MSG)
0x287e: __tmainCRTStartup + 0x10e (quartus_fit)
0x8363: BaseThreadInitThunk + 0x13 (KERNEL32)
0x670d0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 16.1.1
Build: 200
Edition: Pro Edition
