21611 Discussions
Quartus II 11.0 ON Windows XP Error: Current module quartus_map ended unexpectedly
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 11.0 Build 157 04/27/2011 SJ Full Version
Info: Processing started: Sun Nov 20 00:31:20 2011
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off decode38 -c decode38
Info: Only one processor detected - disabling parallel compilation
Info: Found 1 design units, including 1 entities, in source file decode38.v
Info: Found entity 1: decode38
Info: Elaborating entity "decode38" for the top level hierarchy
Info: Timing-Driven Synthesis is running
Info: Generating hard_block partition "hard_block:auto_generated_inst"
Info: Implemented 19 device resources after synthesis - the final resource count might be different
Info: Implemented 3 input pins
Info: Implemented 8 output pins
Info: Implemented 8 logic cells
Info: Quartus II Analysis & Synthesis was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 247 megabytes
Info: Processing ended: Sun Nov 20 00:31:24 2011
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:04
error: current module quartus_map ended unexpectedly
I really can't bear it.
Is there anyone ever came across such problem ???
HELP
I have to emphase that the OS is Windows XP ..
Many people get the same problem with Linux....
did you try 11.0sp1 or 11.1?
you could file a Service Request with Altera or try slimming down the design until it compiles and try to isolate the problem
--- Quote Start ---
--- Quote End ---
I use the Quartus II 9.1 edition to do this simple compiling.It worked well.
And just the quartus 11.0 have this BUG..
this is my code,a 38 decoder module:
module decode38(data_in,data_out);
input[2:0] data_in;
output[7:0] data_out;
reg[7:0] data_out;
always@( data_in )
begin
case(data_in)
3'b000:data_out=8'b0000_0001;
3'b001:data_out=8'b0000_0010;
3'b010:data_out=8'b0000_0100;
3'b011:data_out=8'b0000_1000;
3'b100:data_out=8'b0001_0000;
3'b101:data_out=8'b0010_0000;
3'b110:data_out=8'b0100_0000;
3'b111:data_out=8'b1000_0000;
endcase
end
endmodule
Maybe the two Editions are not compatible on a PC.
Can they be setup at one PC???
THANK YOU A LOT!!
multiple versions of Quartus can coexist on the same PC
so you're saying decode38 won't synthesize on QII 11.0?
--- Quote Start ---
--- Quote End ---
YES.
the error QII gives is "Current module quartus_map ended unexpectedly "
but QII9.1 can run well.
