Programmable Devices
21608 Discussions
Quartus II 13.1 in ubuntu 14.04 MegaWizard error!
ubuuntu 14.04 beta amd64
lenovo ideapad y400
quartus ii 13.1 build 162 10/23/2013 full version
two question:
1,a MegaWizard error occured when generating :qmegawiz command faild out......Fontconfig error.......
I can't upload picture,see the screenshot in the link :http://imagebin.org/299576
I run quartus by following script:
#!/bin/sh export QUARTUS_ROOTDIR_OVERIDE=/opt/altera/13.1 export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/usr/lib/x86_64-linux-gnu/:/home/tracyone/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu ${QUARTUS_ROOTDIR_OVERIDE}/quartus/bin/quartus --64bit
quartus II can't run without lib for i386...so I add stram's lib..
2,the windows size of megawizard is so big for my laptop that i have to rotae my screen to click the button of megawizard ==!
3,How to assocatie *.qpf file to quartus in ubuntu 14.04??
solved the first question:
echo "library for x86..."
sudo apt-get install libxtst6:i386 libxi6:i386 -y
export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/usr/lib/x86_64-linux-gnu/:/usr/lib/i386-linux-gnu
