21430 Discussions
Quartus PGM Error help (Expected JTAG ID code 0x032250DD for device 1, but found JTAG ID code 0x020A
app_engineer
I am using quartus to program a Stratix10 board. The board version is 1sg280hu2f50e2vgs1@1.
After programming the bitfile we are getting an error message in quartus pgm with log:
31:Error (18952): Error status: The device chain in Programmer does not match physical device chain. Expected JTAG ID code 0x032250DD for device 1, but found JTAG ID code 0x020A40DD.
32:Error (209012): Operation failed
34:Error: Quartus Prime Programmer was unsuccessful. 2 errors, 1 warning
35:    Error: Peak virtual memory: 2480 megabytes
36:    Error: Processing ended: Mon Nov  2 12:10:40 2020
37:    Error: Elapsed time: 00:00:11
38:    Error: System process ID: 23316
The quartus version used for this run was :
Info: Running Quartus Prime Programmer
Info: Version 19.4.0 Build 64 12/04/2019 SC Pro Edition
We have been stuck with this error and have tried to look up intel solutions to no avail. Can you please help us find the issue.
YuanLi_S_Intel
May i know which bistream file is used for programming? Based on the error message, it seems like the device number selected in the bitstream is not the same as the device using on the board.
Thank You.
RRomano001
Hello, YuanLi has pointed to what is wrong, just to point to what can be wrong:
JTAG ID code 0x020A40DD belong to ARRIA II GX EP2AGX125EF29C5
Expected code was 0x032250DD belonging to on Board Stratix 10 GX
 Check project device property update device and run again sintesys and planning too.
 If a POF or SOF prebuilt file was chosen, then select the correct one for that board.
app_engineer
I tried changing the version of the device from Engineering Sample board to normal but it still errors out with the same issue.
Does this have to do anything with the MSEL pins on the board?
YuanLi_S_Intel
MSEL is matter depending on the configuration scheme you are using? Tell me, which bitstream you are programming? Is it SOF, POF or JIC?
app_engineer
I am using a SOF file to program the board.
This is the output of my jtagconfig command on the board:
/remote/sbg_toolkits/Altera/quartus_19_4_pro_linux/quartus/bin/jtagconfig
1) USB-BlasterII [1-2.3]
020A40DD 5M(1270ZF324|2210Z)/EPM2210
C32250DD 1SG280HH1(.|S3|AS)/1SG280HH2/..
Is the 020A40DD Jtag ID correct for the Stratix10 GX board?
RRomano001
  1.  MSEL has nothing to do with issue.
  2. MSEL  Select, if multi image design is the case, which one has to boot from.
 From your post Device id on board  is detected and is different from one on programming file you choose for programming.
 I see you are using Linux, this is better choice but has some caveat need be addressed for. Are required library ok? Try launch by shell and look to what happen on terminal.
 Chekup also AN807 about board setup, some dip switch on page 7(not MSEL) appear as selected for JTAG CPLD update.
 Last question again NO : Stratix 10 is on board and detected by JTAG as from previous answer->
JTAG ID code 0x020A40DD belong to ARRIA II GX EP2AGX125EF29C5 (WRONG)
Expected code was 0x032250DD belonging to on Board Stratix 10 GX (Right one(expected for on board device))
https://bsdl.info/details.htm?sid=c1b9a05b8b8b08b888ca59b002289d77
The error you report appear as programming file not prepared for stratix board.
RRomano001
Hi Please partially disregard some detail on previous reply:
About last question, I seen late two device appear on jtag chain, is the right one selected?
 Stratix is the device 2 not the device 1.
 So you assigned stratix file to CPLD EPM2210 or to Stratix? can you post a screenshot of programmer in actual  config
 and then after pressing auto detect button?
app_engineer
When I bring up the programmer this is what I see:
And if I select HH1 device here is the chain:
RRomano001
 Hello, exactly as from jtagd stratix device is chained as device 2, right one on my previous post must sound as correct one.
 On graphic programmer view sound as "right side <-(one)" you are trying program the left device with file built for stratix.
 I don't own this board but looking inside manual instruct use command line programmer directing file to device 1 (Left on graphic version). This seem wrong and generate the error you experienced.
 Double click on right IC image and add file or click on file relative to Stratix, leave CPLD 2210 unselected.
 If you are using command line, board manual use device 1 in chain but on your board this is CPLD not stratix.
 Try change chain device from 1 to 2 and retry.
 And last but not least, never seen as reply, which file are you using for?
app_engineer
I reconnected my previous Stratix10 board which has power issues and was able to notice that the JTAG ID code is different.
The board that I am trying to debug in this thread has the info:
Info (213045): Using programming cable "USB-BlasterII [1-2.3]"
V/S the old board which has the info:
032250DD 1SG280HH(1S1|2S1|3S1)/..
app_engineer
I was able to target the board with JTAG ID CODE C32250DD.
The Stratix10 Part number used for this is:
1SG280HNF43 with JTAG ID CODE :
0xC32250DD
Can you please point me to the PIN assignment for the OSC_CLK (FPGA clock) on board.
Prateik
YuanLi_S_Intel
Just would like to check, which bitstream are you using to programming stratix device? I would recommend you to delete the 2 devices on programmer, then add the bitstream that you want to program into the programmer and then program it. Also, you will need to change the TCK frequency to 6MHz.
Thank You.
YuanLi_S_Intel
Do you mean the location of OSC_CLK_1 on the board?
You may find it on the board schematic available at link below:
https://www.intel.com/content/dam/altera-www/global/en_US/support/boards-kits/stratix10/fpga/s10gx_pcie_devkit_revD.pdf (Page 6)
Also for your information. This thread will is already transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Bruce
app_engineer
Yes the osc_clk_1. I have tried the BA22 pin as per your schematic link, but my design still shows X's on the data bus. Can I use chipscope in quartus to verify the pin for sample clock?
We have a feeling the sample clock is not driving the design.
Also, do you have an example design for this particular board:
0xC32250DD
It would be easier to replicate our design based off of an example design for this part number of the S10 GX board.
