Hey All!
I'm having an issue trying to synthesize and perform timing analysis on a 8 line sorting network. The good news is that I've implemented it with just combinational logic and run a timing simulation in ModelSim for a Cyclone device. The bad news starts now that I need to know the timing for a Stratix V, for which timing simulation is not supported. So I looked into TimeQuest, but it appears to need clocks in order to make constraints for the rest of the design. I think no problem, I'll just make the first stage synchronous by adding a clocked process. But there is a problem, now this little design doesn't want to fit on the huge FPGA. Here's the code, hopefully its formatted correctly. Thanks in advance for any insights!!
library IEEE;
use IEEE.std_logic_1164.all;
entity sort is -- Sorting Network
port ( clk : in std_logic;
rst : in std_logic;
load : in std_logic;
in1 : in std_logic_vector(7 downto 0);
in2 : in std_logic_vector(7 downto 0);
in3 : in std_logic_vector(7 downto 0);
in4 : in std_logic_vector(7 downto 0);
in5 : in std_logic_vector(7 downto 0);
in6 : in std_logic_vector(7 downto 0);
in7 : in std_logic_vector(7 downto 0);
in8 : in std_logic_vector(7 downto 0);
out1 : out std_logic_vector(7 downto 0);
out2 : out std_logic_vector(7 downto 0);
out3 : out std_logic_vector(7 downto 0);
out4 : out std_logic_vector(7 downto 0);
out5 : out std_logic_vector(7 downto 0);
out6 : out std_logic_vector(7 downto 0);
out7 : out std_logic_vector(7 downto 0);
out8 : out std_logic_vector(7 downto 0));
end sort;
architecture behavioral of sort is
type book is array (0 to 7) of std_logic_vector(7 downto 0); -- first define the type of array.
signal bid_book : book; --bid_book is a 16 element array of integers.
signal offer_book : book; --bid_book is a 16 element array of integers.
signal match_vec : std_logic_vector(7 downto 0);
signal market_vec : std_logic_vector(7 downto 0); -- lowest price in offer book
-- Comparator Signals
signal stage1,stage2,stage3,stage4,stage5,stage6 : book;
begin -- circuits of Sm
process(clk,rst)
begin
if(rst = '1') then
offer_book(0) <= "00000000";
offer_book(1) <= "00000000";
offer_book(2) <= "00000000";
offer_book(3) <= "00000000";
offer_book(4) <= "00000000";
offer_book(5) <= "00000000";
offer_book(6) <= "00000000";
offer_book(7) <= "00000000";
elsif rising_edge(clk) then
-- if load = '1' then
offer_book(0) <= in1;
offer_book(1) <= in2;
offer_book(2) <= in3;
offer_book(3) <= in4;
offer_book(4) <= in5;
offer_book(5) <= in6;
offer_book(6) <= in7;
offer_book(7) <= in8;
-- end if;
end if;
end process;
-- Sorting Network Stage 1 - 4 comparators
stage1(0) <= offer_book(0) when offer_book(0) < offer_book(1) else offer_book(1);
stage1(1) <= offer_book(1) when offer_book(0) < offer_book(1) else offer_book(0);
stage1(2) <= offer_book(2) when offer_book(2) < offer_book(3) else offer_book(3);
stage1(3) <= offer_book(3) when offer_book(2) < offer_book(3) else offer_book(2);
stage1(4) <= offer_book(4) when offer_book(4) < offer_book(5) else offer_book(5);
stage1(5) <= offer_book(5) when offer_book(4) < offer_book(5) else offer_book(4);
stage1(6) <= offer_book(6) when offer_book(6) < offer_book(7) else offer_book(7);
stage1(7) <= offer_book(7) when offer_book(6) < offer_book(7) else offer_book(6);
-- Sorting Network Stage 2 - 4 comparators
stage2(0) <= stage1(0) when stage1(0) < stage1(2) else stage1(2);
stage2(1) <= stage1(1) when stage1(1) < stage1(3) else stage1(3);
stage2(2) <= stage1(2) when stage1(0) < stage1(2) else stage1(0);
stage2(3) <= stage1(3) when stage1(1) < stage1(3) else stage1(1);
stage2(4) <= stage1(4) when stage1(4) < stage1(6) else stage1(6);
stage2(5) <= stage1(5) when stage1(5) < stage1(7) else stage1(7);
stage2(6) <= stage1(6) when stage1(4) < stage1(6) else stage1(4);
stage2(7) <= stage1(7) when stage1(5) < stage1(7) else stage1(5);
-- Sorting Network Stage 3 - 2 comparators
stage3(0) <= stage2(0);
stage3(1) <= stage2(1) when stage2(1) < stage2(2) else stage2(2);
stage3(2) <= stage2(2) when stage2(1) < stage2(2) else stage2(1);
stage3(3) <= stage2(3);
stage3(4) <= stage2(4);
stage3(5) <= stage2(5) when stage2(5) < stage2(6) else stage2(6);
stage3(6) <= stage2(6) when stage2(5) < stage2(6) else stage2(5);
stage3(7) <= stage2(7);
-- Sorting Network Stage 4 - 4 comparators
stage4(0) <= stage3(0) when stage3(0) < stage3(4) else stage3(4);
stage4(1) <= stage3(1) when stage3(1) < stage3(5) else stage3(5);
stage4(2) <= stage3(2) when stage3(2) < stage3(6) else stage3(6);
stage4(3) <= stage3(3) when stage3(3) < stage3(7) else stage3(7);
stage4(4) <= stage3(4) when stage3(0) < stage3(4) else stage3(0);
stage4(5) <= stage3(5) when stage3(1) < stage3(5) else stage3(1);
stage4(6) <= stage3(6) when stage3(2) < stage3(6) else stage3(2);
stage4(7) <= stage3(7) when stage3(3) < stage3(7) else stage3(3);
-- Sorting Network Stage 5 - 2 comparators
stage5(0) <= stage4(0);
stage5(1) <= stage4(1);
stage5(2) <= stage4(2) when stage4(2) < stage4(4) else stage4(4);
stage5(3) <= stage4(3) when stage4(3) < stage4(5) else stage4(5);
stage5(4) <= stage4(4) when stage4(2) < stage4(4) else stage4(2);
stage5(5) <= stage4(5) when stage4(3) < stage4(5) else stage4(3);
stage5(6) <= stage4(6);
stage5(7) <= stage4(7);
-- Sorting Network Stage 6 - 3 comparators
out1 <= stage5(0);
out2 <= stage5(1) when stage5(1) < stage5(2) else stage5(2);
out3 <= stage5(2) when stage5(1) < stage5(2) else stage5(1);
out4 <= stage5(3) when stage5(3) < stage5(4) else stage5(4);
out5 <= stage5(4) when stage5(3) < stage5(4) else stage5(3);
out6 <= stage5(5) when stage5(5) < stage5(6) else stage5(6);
out7 <= stage5(6) when stage5(5) < stage5(6) else stage5(5);
out8 <= stage5(7);
end behavioral; -- of Sm
I had a similar issue with the Stratix V and Q11.1SP2. A very simple design was synthesized in 5 sec, and 35 minutes later, there was an error saying the design could not fit. I opened a SR and the altera support reported that there was a bug in the prefitter. The solution was to assign the pin of the clock signal. You can try this and relaunch the compilation. Since I started my Stratix V design, I really have many headaches with Q11 and now Q12.- Mark as New
Ah, I hope this is the solution! I don't have my dev board yet so I didn't see a real need to assign any pins. Thanks for the help! :)
--- Quote Start --- Hey All! ... So I looked into TimeQuest, but it appears to need clocks in order to make constraints for the rest of the design. I think no problem, I'll just make the first stage synchronous by adding a clocked process. ... --- Quote End --- Using Timequest properly assumes that you provide a sdc-file in which you define the timing constraints. Most import is the clock frequency. It is set per default to 1000MHz, which is rather high. You can observe the recognized clocks in the Timequest GUI by clicking Diagnostics -> Report Clocks Defining your own clock (50MHz for example) in a sdc-file:
create_clock -add -period 20.000 -waveform { 0.000 10.000 } -name think_of_a_pretty_clock_name
Thanks for the tip jb123. That's one step past where I am, but it'll help when I get there.
Assigning the clock pin did not fix the problem. I created a top level entity with only a clock and reset pin which instantiates my sorter. I assigned those pins, and it still doesn't fit, so I guess I'll open an SR.- Mark as New
What is the problem reported ? Could you post the message ?
It fits! I appears that I had an issue with my sdc file that I created when I was going through a tutorial. I fixed that, and it looks like I'm good to go!
Thanks everyone!- Mark as New
--- Quote Start --- It fits! I appears that I had an issue with my sdc file that I created when I was going through a tutorial. I fixed that, and it looks like I'm good to go! Thanks everyone! --- Quote End --- Congratulations! NB: If you use a PLL in your design you'll have simply to add
derive_pll_clocks
to your sdc-file after you define the clock mentioned earlier. Note that QuartusII treat all clocks as related clocks by default. That means that if you've clocks in you design that can't be expressed as clock1=n*clock2 where n is an integer and there are paths between these clocks, the Quartus-Fitter will not be able to fit them (no fitter would). This will keep of the fitter to focus on the *really* critical paths. You'll have to treat these "unrelated/asynchronous" clocks in different clock groups like: set_clock_groups -asynchronous
-group {
{think_of_a_pretty_clock_name}
-group {
{clock2_as_seen_in_TIMEQUEST_NAME_FINDER}
Regardless wether constraints you'll use; you'll have to write HDL-code that treats these unrelated clock paths properly. To observe if paths exits between (unrelated) clocks open the Timequest GUI and click Diagnostics -> Report Clock Transfers
