21602 Discusiones
Quatus 2 11.1sp2 error massage
Colaborador Distinguido II
1.388 Vistas
hello.
My quatus 2 generates this error message when I start prpgram/configuration to the device of Cyclone 2 and EPCS1.
the version of Quatus 2 is 11.1sp2
Please help if you know the solution.
Internal Error: Sub-system: PGMIO, File: /quartus/pgm/pgmio/pgmio_jtag_info.cpp, Line: 2363
(src_start_index + n_bits) <= sizeof(DWORD)*8
Stack Trace:
0xbc1c1: PGM_BIT_ARRAY::copy + 0x31 (pgm_pgmio)
0x2ef59: PGME_SFL_ALGORITHM::load_asc_instruction + 0x169 (pgm_pgme)
0x31180: PGME_SFL_ALGORITHM::reset_sfl_asmi_request + 0x20 (pgm_pgme)
0x5ee09: PGME_SFL_ALGORITHM::end + 0x109 (pgm_pgme)
0x7011d: PGME_PROGRAMMER::engage + 0x158d (pgm_pgme)
0xdf76: PGMWQ_PROGRAMMING_THREAD::run + 0x16 (pgm_pgmwq)
0x1e1cc: QThread::setPriority + 0x15c (QtCore4)
0x234c6: _endthreadex + 0xd7 (MSVCR90)
0xb728: GetModuleFileNameA + 0x1b9 (kernel32)
End-trace
Quartus II 32-bit Version 11.1 Build 259 01/25/2012 SJ Web Edition
Service Pack Installed: 2
0 kudos
3 Respuestas
589 Vistas
I am seeing the same issue trying to program an EPCS128 flash device of a Cyclone 2 Altera devices. I am using version 12.0SP2.
Internal Error: Sub-system: PGMIO, File: /quartus/pgm/pgmio/pgmio_jtag_info.cpp, Line: 2498
Stack Trace:
0xc1431: PGM_BIT_ARRAY::copy + 0x31 (pgm_pgmio)
0x31319: PGME_PROGRAMMER::generate_svf_files + 0x7929 (pgm_pgme)
0x33680: PGME_PROGRAMMER::generate_svf_files + 0x9c90 (pgm_pgme)
End-trace
Quartus II 32-bit Version 12.0 Build 263 08/02/2012 SJ Full Version
589 Vistas
Hello.
My case, this problem is solved after updating Quatus 2 to version 12.0.
I think you should try updating Quatus 2 to newest version.
589 Vistas
I think its always the first step to update to the latest Version as long as this is an option in regards too either devices are supported in latest Version (old device families as e.g. ACEX, Cyclone (1st Edition), .. aren't). Sometimes formal project requirements may force you to use the old version to be compliant with the developement, while this is more industry specific. Last reason to stay with old Version is having a Full Version and no valid maintenance subscription (and falling back to WebEdition is no option)...
Otherwise, as a collegue of mine picturized, using old releases is like reading last week's newspaper :-D
Responder
