Hi all. I am trying to implment a Dual port RAM using CycloneIII EP3C10. As listed by the handbook, EP3C10 has 46 M9K Blocks. I want to configure the memory as 5120 × 32bit. MegaWizard tell me the memory need 32 M9K. My question is whether I could reduce the num of M9K according to some setting with Maximum Block Depth.
thx.Link Copied
The megawizard isn't able to optimize the use of memory blocks when the size isn't a power of two. To reduce the blocs usage you must create two memories, one 4096*32 and one 1024*32, and add some logic to select which block to use.
