I wrote a code that works very well in ModelSim but when I’m trying to burn the code on the MAX 2 CPLD (EPM2210F256I5) the software is not running as expected (and I think it even stuck …). On the Processing labels I get info about tco= 10.010nsec, tsu= 7.470nsec, th= -14.413nsec clock setup: 78.46MHz (I’m working with 10MHz clock). Is this could be the code problem? What should I do? IdanLink Copied
