21615 Discussions
Question about Monitor
is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
--- Quote Start ---
--- Quote End ---
No. The monitors are there to generate assertion messages regarding Avalon-MM bus protocol violations.
Cheers,
Dave
Thanks Dave. I came across some papers which discussed about developing monitors in SVA [System Verilog Assertion Language] and it stated that these monitors can be synthesized.
"This paper presents one implementation of the Open Control Protocol (OCP) monitoring on the synthesized FPGA design using the implemented library of Synthesizable SystemVerilog Assertions (SSVA). The SSVA library is developed using the layer structure of SystemVerilog assertions. It is used in implementation of the monitors for two profiles of the OCP. SSVA library and OCP monitors are then functionally verified in simulator using the test case of the processor-memory communication. The test case is then synthesized on CHIPit Platinum Edition FPGA. The implemented library and monitors can be used in many commercial and educational projects due to their simplicity and low FPGA area usage."
--- Quote Start ---
--- Quote End ---
Have a look at the source code. I think you'll find it wrapped in synthesis off/on blocks so that Quartus never even sees the code. That's certainly the case for the Avalon-MM master BFM component.
The complication regarding synthesized assertions, is that an assertion needs some method of reporting failures, so a synthesizeable assertion checker would need an Avalon-MM interface with a block of control/status registers so that you could check for assertion failures, and clear error counters. But if your transaction just locked up the Avalon-MM bus, how would you read that register?
You really don't want your transactions to fail in real hardware. That is what verification testing is for in the simulator :)
Cheers,
Dave
Monitors can be synthesized but not recommended right?. I will do some reading and get back to you about this.
I have just started Qsys a few weeks ago, apart from the tutorials provided by qsys are there any other online tutorials/ good books about qsys.
Thank you,
Aditya
--- Quote Start ---
--- Quote End ---
You're missing the point. The task of a monitor is to confirm that components adhere to the bus protocol specification. If a component will violate the bus specification, then its likely the bus will lock-up, and your system will freeze. Sure you can have a watch-dog reset the bus, and perhaps have a 'reset reason' and a backtrace. But all this can be reproduced in the simulation much easier. You setup randomized bus transactions, and code coverage, etc., and make sure things are well tested. Then you can synthesize.
--- Quote Start ---
--- Quote End ---
Sure. I'm not saying they don't exist, but the question is what use are they? Feel free to come up with a good reason :)
--- Quote Start ---
--- Quote End ---
You will learn best by building components, constructing _hw.tcl files, and synthesizing them. The nice thing about this approach is that you can get Quartus to generate an _hw.tcl file for some simple components, and then read the documentation about the settings. Things will make much more sense then.
The Quartus handbook has chapters on Qsys. I think alot of the component stuff is the same as the SOPC Builder stuff, so you can look at that manual too.
The Qsys tutorial has layers of hierarchy, since Altera wants to show off the new features of Qsys relative to SOPC Builder. Rather than using that to learn from, try to create a design with an Avalon-MM BFM master, and an Avalon-MM slave registers interface; don't use the PIO core, write your own. Then write a SystemVerilog testbench to generate read/write transactions to your registers.
You can add an Avalon-MM monitor into your testbench, and then generate transactions that violate the bus specification, eg. perform a read or write with invalid byte enables and see the assertion failure messages. You must have a tool that supports System Verilog Assertions (SVA), like the full version of Modelsim, otherwise you will not get the SVA messages.
Cheers,
Dave
Hello Dave,
Thank you for your quick response Dave.
Yes, I have written simple programs [test_program.sv] for simple systems. [These systems have no bus. I am just writing to an on-chip RAM. In the first layer/level, I only have a ram, a clock and a reset. Next I export the slave of RAM [the default name is s1]. The clock and reset are already exported by default. Then I attach clock BFM, reset BFM and Avalon Master BFM to the top level [containing ram and clock] system instance. Later I write a test program containing API's to write data, read etc....]. this works and i can see the written data in the ram.. But I am not using any Bus [such as PCIe/ixp bus] and the connection is through the Avalon switch fabric.
system 2:
Now, when I include the bus [I am using a simple expansion bus [ixp]] and when I connect the master of the bus to the slave of the RAM, here are the difficulties I face:
a) How do I use the BFM to write data [I want to use the API's for the Avalon Master BFM given in the API manual] to the RAM [remember the master of the BUS is connected to the slave of the RAM].
Since the mater of the BUS is connected to the slave of the RAM, I cannot export the RAM's slave pin because, then the connection between the bus.master and ram.slave gets disconnected. So the only thing I can do is to drive the slave of the BUS. But when I drive the slave of the BUS using Avalon MM BFM, I can only write to the memory locations of the slave of the bus using the API's, my big question is : "how do i access the memory locations of the ram", with a bus ip between Avalon MM master BFM and the on chip RAM
my questions after trying to implement system 2[above]
The reason why I am trying to implement the above system is, I read in the tutorials that in order to test a system, you need to export some of the pins to which you apply the stimulus using the BFM's.
questions
a) Is it even possible to implement such a system [like what I am trying to do above]
b) Is it necessary to test the systems only using BFM's?
c) Based on what I know, if you want to test any system in Qsys you need to export the signals right? without exporting you cannot test anything right?
d) Am I supposed to use APIs' only to test individual components and not the entire system?
I have tried to explain things as clearly as possible, If I still haven't explained the problem clearly, I will explain it one more time with some screen shots.
Thanks a lot for you time and effort,
Aditya
Hi Aditya,
--- Quote Start ---
... These systems have no bus ... I am not using any Bus [such as PCIe/ixp bus] and the connection is through the Avalon switch fabric.
--- Quote End ---
The Avalon switched fabric is a bus protocol. The Altera Verification IP Suite contains BFMs for testing the protocol(s).
--- Quote Start ---
... when I include the bus [I am using a simple expansion bus [ixp]] ...
--- Quote End ---
What is IXP? Is it the old ARM XScale bus?
--- Quote Start ---
... when I connect the master of the bus to the slave of the RAM ...
--- Quote End ---
If you have an external processor connected to an Avalon fabric, then the interface should be an IXP-to-Avalon bridge. If the external bus can only be owned by the processor, then the bridge will only have an Avalon-MM master interface on the Avalon side. If however the external bus can be arbitrated for by the processor or the FPGA, then the Avalon interface can have both master and slave interfaces.
--- Quote Start ---
... here are the difficulties I face ...
--- Quote End ---
The Altera Verification IP suite Avalon BFMs are for testing Avalon components.
For an IXP-to-Avalon bridge design, you would require both Avalon BFMs and IXP BFMs, and monitors for those buses. The testbench for your bridge design would contain your bridge component, the bus monitors, and the BFMs. Your test case generator would throw lots of transactions at the design in an attempt to test every path through your bridge code (code coverage would tell you what is missed). Illegal activity would trigger assertion violations. Your tests would include transactions where both the IXP master and an Avalon-MM master issued transactions to the RAM and checked the results. This would result in simultaneous accesses that would be arbitrated by the slave-side arbitration inside the FPGA.
--- Quote Start ---
--- Quote End ---
I think I have understood what you are trying to do, but a block diagram would help clarify.
Cheers,
Dave
Hello Dave,
Thanks for you reply!.
What does the error " Error(10744): Verilog HDL error at verbosity_pkg.sv : functions cant enable tasks" mean. The verbosity package is generated by quartus.qsys. I have not modified that file either"
--- Quote Start ---
--- Quote End ---
I have not seen that error.
Please check you have enabled SystemVerilog in Modelsim; Compile menu, Compile Options, Verilog&SystemVerilog tab, and make sure SystemVerilog is checked as the language.
Cheers,
Dave
Hello Dave,
yep figured it out!. Thanks. When i try to compile a a design involving a custom component I get the following errors. The error screen shot is attached. http://www.alteraforum.com/forum/C:\Documents and Settings\aashoka\My Documents\My Pictures\ixp_error.bmp
The .tcl file associated with the custom component is present in the .qsf file [the path is present]. Why is the error still occuring.
Adi
The errors are here:
Error: June10_ram2.ixp465_rwdata_0: Component ixp465_rwdata 1.1 not found
Error: June10_ram2.ixp465_rwdata_0.ixp_master/ram.s1: Illegal connection start (ixp465_rwdata_0.ixp_master is an end interface)
Error: Ixp465_rwdata_0.ixp_master/ram.s1: Connection ixp465_rwdata_0.ixp_master/ram.s1 has missing start or endpoint
--- Quote Start ---
--- Quote End ---
Look in your project; does it include the code for component with pin ixp465_rwdata? Or perhaps this is a typo?
Rather than coding the _hw.tcl file directly, have the component editor automatically generate the _hw.tcl file, and then edit it to customize it. If your code is VHDL, and it includes components, eg., library mylib; use mylib.components.all;, then you'll need to include the 'components' package before your custom component, otherwise Quartus will complain. Iterate a few times, reading the errors, until you get it right.
Before trying to make a component _hw.tcl file based on untested VHDL or Verilog source, make sure it compiles with Modelsim first.
Cheers,
Dave
Hello Dave,
I have connected the custom component to "Onchip RAM" and I am able to wire data to the memory. [I first Generate the simulation files in Verilog and attach only the Clock and Reset BFMs. Then using the test bench I write data to the ram using some tasks and observe the result in the memory viewer window] The .tcl file of the component is working fine. What I don't understand is the missing start/end point in the error message ?
E=mc2
--- Quote Start ---
--- Quote End ---
Does SOPC Builder give you this error, or Modelsim? If its SOPC Builder, then these sound like _hw.tcl keywords; check the syntax in your component file.
Cheers,
Dave
The SOPC gives these errors. I'm sorry, can you elaborate on how the _hw.tcl - keywords is responsible for this error.
--- Quote Start ---
--- Quote End ---
Look inside your _hw.tcl file for your new component. SOPC builder is complaining about 'start' and 'end' keywords, and something that is defined as a 'start' connection, when it is defined as an 'endpoint'.
I don't use SOPC Builder enough to know what these errors are due to. As I mentioned earlier, I generally let SOPC Builder generate the first version of _hw.tcl and then edit that.
I think you have some interfaces defined incorrectly. Move your _hw.tcl file someplace else, and use component editor to help create a new file. Then get it working. Finally, compare your original _hw.tcl file to the new one to see where you went wrong.
Cheers,
Dave
Got it!. All this time I was adding the files that were meant for simulation and had unchecked the synthesis option.
--- Quote Start ---
Got it!
--- Quote End ---
Great!
Cheers,
Dave
Hey Dave,
When I try to import an older system into Qsys I get the following errors and doubts:
errors:
1. component xxx must have an associated reset. [i edited the pins and got rid of the error for one of the simple design.]. does qsys create a global reset pin ? [ i get this for all the components
2. it says asks me to replace pci-compiler with a compatible component. doubts
a. Why does it not complain about not finding the PCI-compiler IP in it's IP list?
b.Automatically coundits show up in all the components [What are they?(i read the manual, but not satisfied with explanation) and why are they created]. I Igonered the conduits in one of my designs: the simulation worked fine and I could also run the "compile Design without any errors"
c. Instead of creating the new system with PCIe, can I use the MegaIP wizard to modify the PCI-compiler and then add it to my Qsys system. [Any component is related with only two files right?; its verilog file and _hw.tcl file]
Thanks and have a joyous day,
Aditya
--- Quote Start ---
--- Quote End ---
I haven't used Qsys to import SOPC Builder projects, so cannot help answer your questions.
Try posting a new thread with a title like "Errors when importing SOPC system into Qsys", and see if someone else can offer advice.
Cheers,
Dave
