21595 Discussions
Question about optimizing a VHDL based system.
Hi all,
I finally managed to have my system to work as I expected but I am quite dissapointed with the too high number of LEs required by the entire project.
I wanted to know if you had books or websites that deal with optimization specifically.
I also wanted to know if reducing some bus size would reduce the number of LEs.
I have many 512 bits buses that I could probably break down into chunks of 32 bits by adding a "loading" process but I don't know if it will help.
By the way my project is open source so you can have a look at my sources and feel free to give me any tips regarding the coding style.
https://github.com/accpnt/sha1
Thanks for your answers.
why such wide busses? couldnt you have pipelined the designed and put the data through rams?
Have a look at the fitter compile report > Resource Section > Resource Utilization by Entity. There you can find out if one of your components stands out in resource usage or if it's a problem spread around your design.
Large buses can lead to heavy resource usage, and usually 512-bit buses shouldn't be necessary if you don't need a huge data bandwidth. That said if all your logic operates on 512 bit words, serializing and deserializing them in 32-bit buses to interconnect several components together probably won't help much.
I've decided to reduce the bus sizes and I've managed to double the depth of my pipeline.
I also want to put the largest registers in RAM but I don't really know how to do it.
I've found the following doc : http://quartushelp.altera.com/12.1/mergedprojects/hdl/vhdl/vhdl_file_dir_ram.htm
I followed the procedure like this :
-- First, declare a signal that represents a RAM
type memory_t is array (0 to 15) of std_logic_vector(31 downto 0);
signal my_ram : memory_t;
attribute ramstyle : string;
attribute ramstyle of my_ram : signal is "M9K";
But in the Fitter report it says that 0 M9K out of 66 have been used.
Did I miss something ?
Cheers,
that is a very small memory. Also, you need to ensure your my_ram signal actually behaves like a ram - otherwise you cannot create one. The ramstyle attribute means nothing if it doesnt infer a ram.
Refer to the HDL coding guidelines for hardware inference
http://www.altera.co.uk/literature/hb/qts/qts_qii51007.pdf
