Programmable Devices
21607 Discussions
Question about the PL-USB2-BLASTER
SidCamacho
We bought the PL-USB2-BLASTER from Mouser and Digi Key, and in both orders the product arrived with the information “Engineering Sample”. See attached.
Is the product safe and ready to use?
Thanks and best regards
Sidonio
sstrell
USB Blaster II is like 15 or 20 year old tech at this point (if not older).  I don't know why it says "Engineering Sample" but I wouldn't worry.
FvM
user guide release 1.0 is from Jan. 2014, thus 11 years old. ES version is most likely distributor stock of similar age. The product has no electrolytic capacitors as far I'm aware of and doesn't age fast.
Semi-E
Since the day code is so old, you probably received original Engineering samples that were not available for distribution. In most cases, they are unlimited supply. It’s like when a product runs out of stock in a store, and a customer wants one really bad. They will usually take the floor model.
Farabi
Need to ask from distributor if you want to replace the USB Blaster II with non-ES version.
regards,
Farabi
SidCamacho
We tried two different distributors, Digi Key and Mouser, and both of them delivered the ES version.
It seems to be the only version in the market now.
Is it safe to use?
Semi-E
NurAiman_M_Intel
Have you contacted with your distributors and ask them why they shipped the ES version? And ask if they can shipped USB Blaster that is not ES?
To answer your question, of course there is not problem to use the ES version.
Aiman
NurAiman_M_Intel
  • As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
