21615 Discussions
Question about the VHDL sequential statements
I just got some questions with the following processes when I design a simple MOD-9 counter for concept clarifications:
1. In program 1, the simulation result is actually counting from 0 to 10, not 0 to 9. Is that because "q <= q +1;" and "if (q = 10) then" block are Concurrently executed? Does that mean within the if..else... statement, the codes are also concurrently executed?
2. I understand that process 2 is not working fine because it is not synthesis-able, but why program 3 is working fine?
Thanks a lot!
Program 1:
process(clk,set,q)
begin
if reset='0' then
q <= 0;
elsif clk'event and clk='1' then
q <= q +1; -- this is a counter that counting from 0 to 10, but not 0 to 9.
if (q = 10) then -- want to avoid number 10 after q++, but it still has 10 shown up in the result.
q <=0;
end if;
end if;
end process;
Program 2:
process(clk,set,q)
begin
if (q = 10) then -- this is not synthesis-able. i understand it.
q <=0;
end if;
if reset='0' then
q <= 0;
q <= q +1;
end if;
end process;
Program 3:
process(clk,set,q)
begin
if reset='0' then
q <= 0;
q <= q +1;
end if;
if (q = 10) then -- but compared to program 2, why this code is working fine after i put the "if (q=10) then" part to the end of the process?
q <=0;
end if;
end process;
Although you may see program 3 "working fine", it's not guaranteed to do. Depending on timing details, the counter may possibly count to 7 instead of 9. It's no correct synchronous description.
Program 1 is the correct counter code, but you need to understand the clearly specified behaviour of sequential processes. All signals are updated after the end of the process. the comparison "if q = 10" (no brackets required in VHDL, by the way) "sees" the previous counter value, not the new one.
The below style emphasizes the actual operation of the code more clearly, I think.
if q = 9 then q <=0; else q <= q + 1; end if;
Thanks a lot. Now I got the idea:
If there are more than one assignments to the same signal value in sequential statements of one process. Only the last one will be effective.
--- Quote Start ---
--- Quote End ---
