Hi
please, there are some difference between uses of Block Diagra/Schematic File or SOPC builder as top level-entity? :(:(Link Copied
In case of your design will contain extra logic (like a tristate buffer to interface with GMII ethernet for example), You must have a top level entity that contain SOPCBuiler component. I haven't seen SOPC Builder as top level. Other users would give more information. ++- Mark as New
--- Quote Start --- Hi, In case of your design will contain extra logic (like a tristate buffer to interface with GMII ethernet for example), You must have a top level entity that contain SOPCBuiler component. I haven't seen SOPC Builder as top level. Other users would give more information. ++ --- Quote End --- Thank you frien. Alos i use SOPC as top level. But i need to know if there some difference. May be there someone that can clarify this.:)
