I want download program to EPM3256ATC144 via JTAG, use USB Blaster in QuartusII. But I found the following problem:
1) I could ERASE the CPLD successful. 2) "JTAG Chain Debugger" of QuartusII checked everything is good. 3) But I could not download to the CPLD, the following will be showed when download via JTAG: 3.1 Error: Can't access JTAG chain 3.2 Error: Can't recognize silicon ID for device 1 4)I get the USERCODE is FFFFFFFF I want to know which cause these problem and how to solve it. ThanksLink Copied
What sort of chip does the Quartus programmer auto-detect the hardware as? "Can't recognise silicon ID suggests that you might have selected the wrong device in Quartus or something like that".
Thanks. The Quartus programmer auto-detect the hardware as EPM3256ATC144 which is the same device I set in the project.
I can't solve these trouble till now.- Mark as New
If it all matches up then my guess is that you have some sort of noise issue affecting your jtag pins. Sorry I can't be more specific.
![](/skins/images/48A1642489FEF8D34D940AC6791CBDC2/responsive_peak/images/icon_anonymous_message.png)
Topic Options
