20764 Discussions
Question for download to EPM3256ATC144 via JTAG
I want download program to EPM3256ATC144 via JTAG, use USB Blaster in QuartusII. But I found the following problem:
1) I could ERASE the CPLD successful.
2) "JTAG Chain Debugger" of QuartusII checked everything is good.
3) But I could not download to the CPLD, the following will be showed when download via JTAG:
3.1 Error: Can't access JTAG chain
3.2 Error: Can't recognize silicon ID for device 1
4)I get the USERCODE is FFFFFFFF
I want to know which cause these problem and how to solve it. Thanks
What sort of chip does the Quartus programmer auto-detect the hardware as? "Can't recognise silicon ID suggests that you might have selected the wrong device in Quartus or something like that".
Thanks. The Quartus programmer auto-detect the hardware as EPM3256ATC144 which is the same device I set in the project.
I can't solve these trouble till now.
If it all matches up then my guess is that you have some sort of noise issue affecting your jtag pins. Sorry I can't be more specific.
