21615 Discussions
Question on Arria 10 FPGA Development Kit User Guide
MK_ABQ
New Contributor III
UG-20007
2021.03.19
In the following section ( picture below), it says "These devices are part of the shared FM bus that connects to the flash memory and MAX V
CPLD EPM2210 System Controller."
Question : I believe EPM2210 is a MAX II CPLD. Why does the user guide says MAX V CPLD EPM2210?. Is this  a typo in the user guide?. Can you please explain?
sstrell
There's a MAX II for the onboard USB blaster and a MAX V (5M2210).  See the schematic:
https://www.intel.com/content/dam/altera-www/global/en_US/support/boards-kits/arria10/FPGA/A10GX_PCIE_E3p1.pdf
MK_ABQ
New Contributor III
Hi sstrell,
Thanks for the response.  I have further three more questions.
Q1) So the Max II CPLD is the system controller is it?
Q2) And also what is the usage of EPCQ1024L in page 14 of the schematic?.
Q3) I understand Max II & Max V are used for configuring the on board USB blaster, and control configuration of FPGA from flash respectively. Is  my understanding correct?
Thank you.
sstrell
1) no like I said, the Max II is for the USB Blaster. Again see the schematic. There’s a block diagram on the first page.
2) I’m not at my computer now but that’s a configuration device with flash memory to store programming data.
3) yes.
MK_ABQ
New Contributor III
Great!. The answers are clear. I am gonna shoot more basic questions to help me understand the specifics. Please bear with me.
Now, moving further to how the 1-Gbit flash memory is connected, I see that there are two flash chips (u4), and (u5) in the schematic which shares an Address bus, and also two interesting notes in blue color at the bottom. (attaching picture below).
I would like to understand, why the connection in made in such a way with 2 flash memories?. Is there a specific reason?
And, what does the note in the blue signify?. I believe as per the schematic, I should focus on the 2nd note which mentions about dual flash device. Am I right?
sstrell
You can access a single flash chip as x16 or use both to use a larger flash as x32.
MK_ABQ
New Contributor III
Thanks, got that point.
I am intrigued on these statements.  Can you possibly give a little bit more info on these?. I do not comprehend on the logic, intention behind it.
