Hello;
In my design I write a VHDL code to infer ROMs. It were specified to be M9k with the following attribute: attribute romstyle : string;attribute romstyle of q: signal is "m9k"; Then after compiling I didnot find these settings in the fitter report, however, I find other attributes for the other entities. Also the ROMs are inferred with the Altsync_ram function but didnot consume any M9K blocks. each ROM size is 8*256 I use the stratix3-EP3SL150F1152 chip. My question is what attributes can force the synthesis to use M9K bloks to infefer these ROMs? Thanks
If you are using the altsync_ram IP block, then you are not inferring a rom. Inference is done by writing behavioural RTL that behaves like a ram and the synthesis will replace your code with an altsyncram. If you are using an altsynram you need to set the ram style paramters.
There are examples of inferred memory in volume 1 chapter 12 of the Quartus handbook.
