Programmable Devices
21594 Discussions
RS232 sends to terminal but doesn't recieve!!
Hello every one
Im using Altera FPGA DE0 board and I need your help in serial communication
I use SOPC builder to design the hardware needed (that was a microcontroller
with rs232 prephiral with 2 pins used to send and recive)
I used Nios2 to write the code
first I tried to hyper terminal of the PC and it works
then I tried to receive by using "getc" function but didn't work
any ideas .. I need to send and receive .. so plz help
thanks in advance
http://www.altera.com/literature/hb/nios2/n2cpu_nii51009.pdf
check page 7 of this document. Maybe it will be of some help
hey did u found a solution for the Problem ? i got the same on my NEEK
