21611 Discussions
RTL and gate-level synthesis
Hi everybody!
Now I'm trying to examine the FPGA project design flow. And I'm confused because of some concepts. Do RTL- and gate-lavel synthesis mean the same? If they differ could you explain their differences?
thank you in advance!
Refer to the chapter quartus ii integrated synthesis in Quartus software manual.
VerLearn
In a nutshell, RTL (Register Transfer Level) (Pre-Synthesis simulation) is the digital circuit that consists of combinational logic, memory elements, and clocks. The simulation takes place without any delays. Eg: Consider a half adder. module HalfAdder( output sum, output carry, input input1, input input2); assign sum=input1^input2; assign carry=input1&input2; endmodule The RTL schematic contains an XOR gate and an AND gate. This RTL schematic is generated by simulation tool. GATE level simulation (Post synthesis simulation): The synthesized RTL schematic is run with the provided timing delays. Gates are taken from the cell library. Note: Sometimes, GATE level simulation results and RTL simulation results may not match. The answer is simple. If you use constructs that are not available to the synthesis tool, results vary.
