21611 Discussions
Helpless about 1588V2
mark_lee
I run the project "LL10G_1G_10G_LINESIDE_1588v2" on the demo board "Arria 10 SOC Development Kit"
1588V2 thranceive an receive are OK ;  I made project run on my board(10AS066H3F34I2SG) , it is cannot receive anything .
can  the chip "10AS066H3F34I2SG" surport the 1588v2  ?
% TEST_1588 0 1 10G
CONFIGURE CHANNEL 0 as master
configure_to_10G
setting up mac with a basic working config
setting 0xC5C4 into rxmac primary address Reg-1
setting 0xC3C2C1C0 into rxmac primary address Reg-0
enabling: pad and crc stripping in rx mac
testing Configure Period and Adjustment RX XGMII TSU
Configure Period and Adjustment TX XGMII TSU
clearing mac stats registers
Configure TOD Master
Configure TOD 10G
Disabling serial PMA Loopback (local)
Read back Serial PMA loopback register = 0x00000000
CONFIGURE CHANNEL 1 as slave
configure_to_10G
Configure TOD 10G
Select 1588 traffic controller
Start TOD synchronization
Master 1588 start 1 step operation
TRAFFIC_CONTROLLER_BASE_ADDR: 0x100000
Waiting capturing offset delay ...
-- Break
Start capturing offset delay ...
Reset Master 1588 start 1 step operation
Reset Start TOD synchronization
delay ns = 0x00000000
delay fns = 0x00000000
offset ns = 0x00000000
offset fns = 0x00000000
| MAC TX STATS REGISTER CHECK
|# FRAMES_RECEIVED_WITH_ERROR = 0
|# UNICAST_FRAMES_WITH_ERROR = 0
|# MULTICAST_FRAMES_RECEIVED_WITH_ERROR = 0
|# BRDCAST_FRAMES_WITH_ERROR = 0
|# FRAMES_RECEIVED_WITH_ONLY_CRCERROR = 0
|# VALID_LENGTH_FRAMES_WITH_CRC_ERROR = 0
|# JABBER_FRAMES = 0
|# FRAGMENTED_FRAMES = 0
|# INVALID_FRAMES_RECEIVED = 0
|# FRAMES_RECEIVED_GOOD = 0
|# PAUSE_FRAMES_RECEIVED = 0
|# UNICAST_CONTROL_FRAMES = 0
|# MULTICAST_CONTROL_FRAMES = 0
|# UNICAST_FRAMES_RECEIVED_GOOD = 0
|# MULTICAST_FRAMES_RECEIVED_GOOD = 0
|# BRDCAST_FRAMES_GOOD = 0
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 0
|# COMPREHENSICE_OCTETS_RECEIVED = 0
|# FRAMES_WITH_SIZE_64_BYTES = 0
|# FRAMES_BETWEEN_SIZE_64AND127_BYTES = 0
|# FRAMES_BETWEEN_SIZE_128AND255_BYTES = 0
|# FRAMES_BETWEEN_SIZE_256AND511_BYTES = 0
|# FRAMES_BETWEEN_SIZE_512AND1K_BYTES = 0
|# FRAMES_BETWEEN_SIZE_1KND1518_BYTES = 0
| MAC RX STATS REGISTER CHECK
|# JABBER_FRAMES = 0
|# FRAMES_BETWEEN_SIZE_ABOVE1519_BYTES = 0
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
Caguicla_Intel
Hello mark_lee,
Your query will be best answered by our Intel Field Programmable Gate Array (FPGA) Support team, we will help you to move this post to the designated team for further assistance.
Please feel free to contact us if you need assistance from Intel Ethernet support team.
May you have a great day!
Crisselle C
Intel® Customer Support
mark_lee
hi  TEAM
In addition:  demo board "Arria 10 SOC Development Kit" use the chip"10AS066N3F40E2SG";
                     my project use the chip "10AS066H3F34I2SG
Deshi_Intel
HI,
May I know which Ethernet ref design that you are referring here ?
  • Any download link or do explain to me how you generate the ref design ?
Typically 1588 feature follow Ethernet IP and has less dependency on FPGA device speedgrade. Since both A10 SOC dev kit and your board are using Arria 10 FPGA, it should work.
Which means the failure is either due to Quartus design issue, board setup issue or board design issue. The good news is you at least have a golden working ref design on A10 SOC dev kit board. You just need to compare and find out the difference that may caused the failure.
  1. To rule out Quartus design issue
  • I presume you use back same ref design without changes to the RTL design ?
    • Does the design met Quartus timequest timing closure ?
    • Also pls verify the qsf setting particularly on pin location and IO standard setting to match with your own board
  1. To rule out board setup issue
  • Pls double check on FPGA reset, power and clocking
    • Your log file shown zero Tx and Rx transaction where I suspect either your design is stuck in reset or clocking is not provided correctly
    • Or maybe some FPGA pin location or IO standard is set wrongly
  1. To rule out board design issue
  • Can your board handle 10G data transfer without concern on signal integrity issue ?
    • Have you try to use transceiver toolkit to perform loopback testing on your board to verify 10G signal transfer is good on your board first ?
dlim
mark_lee
Hi Deshi ant team
1. The Project  "LL10G_1G_10G_LINESIDE_1588v2" is builded Reference the Intel Example "a10soc_322265325_Scalable_Eth1588_BUG2613_Quartus_16.1.0";
2. My Project is working on the Quartus Prime pro 19.2;
3.I have running my project on my board ,"TEST_SMA_LB 0 1 10G " is ok;
4.I have running my project on my board ,"TEST_PHYSERIA_LOOPBACK " is ok;
5.When finish TEST_PHYSERIAL_LOOPBACK , and running“TEST_1588 0 1 10G"  right now,sometime frames received is good , "offset ns" and "delay ns" are good   , but when runningTEST_1588 again it is receive annything  。
mark_lee
Hi Deshi ant team
In addition:
1. "TEST_SMA_LB 0 10 G 5000 " and "TEST_PHYSERIAL_LOOPBACK "1 10G 5000" are  ok, message is :
(1)
% TEST_SMA_LB 0 10G 5000
CONFIGURE CHANNEL 0
configure_to_10G
Configure TOD 10G
Select std ethernet traffic controller
Disable Avalon ST Loopback
B E G I N C O N F I G U R A T I O N
payload length = fixed ....
payload bytes = fixed incremental bytes ....
burst size = 5000 ....
payload length = 100 ....
frame source addres field = F0F1F2F3F4F5 ....
frame destination addres field = C5C4C3C2C1C0 ....
reseting monitor Packet Counters
number of Packets Expected By Monitor = 0x1388
burst being injected into device ....
-- MONITOR processing frames received .....
-- MONITOR Received Packet# 5000]
-- DONE! - monitor received all expected sum of packets .....
_________________________________________________________________________________________________________________________
-- (MONITOR) GOOD PKTS RECEIVED = 5000
-- (MONITOR) BAD PKTS RECEIVED = 0
-- (MONITOR) BYTES RECEIVED = 479992
-- (MONITOR) CYCLES USED = 75002
-- (MONITOR) THROUGHPUT CALCULATED = 8.00 Gbps
-- (MONITOR) RXBYTECNT_LO32 = 479992
-- (MONITOR) RXBYTECNT_HI32 = 0
-- (MONITOR) RXCYCLCNT_LO32 = 75002
-- (MONITOR) RXCYCLCNT_HI32 = 0
|# JABBER_FRAMES = 0
|# FRAMES_RECEIVED_GOOD = 5000
|# MULTICAST_FRAMES_RECEIVED_GOOD = 5000
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 410000
|# COMPREHENSICE_OCTETS_RECEIVED = 500000
|# FRAMES_BETWEEN_SIZE_64AND127_BYTES = 5000
|# JABBER_FRAMES = 0
(2)
% TEST_PHYSERIAL_LOOPBACK 1 10G 5000
CONFIGURE CHANNEL 1
configure_to_10G
Configure TOD 10G
Enabling serial PMA Loopback (local)
Read back Serial PMA loopback register = 0x00000001
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
mark_lee
Hi Deshi ant team
1.   I do some test forward the step :
(1) "TEST_PHYSERIAL_LOOPBACK 1 10G 5000”   ,is OK
(2) “TEST_1588 0 1 10G ”    is OK
(3) "TEST_1588 0 1 10G" again,  is not OK
2.  The console system print message is :
CONFIGURE CHANNEL 1
configure_to_10G
Configure TOD 10G
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
% TEST_1588 0 1 10G
configure_to_10G
Configure TOD 10G
configure_to_10G
Configure TOD 10G
-- Break
delay ns = 0x00000030
delay fns = 0x00007197
|# JABBER_FRAMES = 0
|# FRAMES_RECEIVED_GOOD = 9120026
|# UNICAST_FRAMES_RECEIVED_GOOD = 9120026
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 456001300
|# COMPREHENSICE_OCTETS_RECEIVED = 620161768
|# FRAMES_WITH_SIZE_64_BYTES = 4560013
|# FRAMES_BETWEEN_SIZE_64AND127_BYTES = 4560013
|# JABBER_FRAMES = 0
|# FRAMES_RECEIVED_GOOD = 4560013
|# UNICAST_FRAMES_RECEIVED_GOOD = 4560013
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 209760598
|# COMPREHENSICE_OCTETS_RECEIVED = 291840832
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
% TEST_1588 0 1 10G
configure_to_10G
Configure TOD 10G
configure_to_10G
Configure TOD 10G
-- Break
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
Deshi_Intel
Hi Mark,
I presume you are still using below ref design "unchanged" or you had modified the design ?
Let's clarify your problem statement before we discuss about debug plan :
  • Your latest update mentioned 1588 hardware testing sometime pass, sometime failed, right ?
    • Does the failure occurs randomly or always after 2nd time of 1588 hardware testing ?
    • Does reset the system and retest 1588 makes it to pass again ?
    • When 1588 test failed, does the statistic log always show zero value ? This looks to me your design or system is stuck rather than receive wrong/bad data issue
For the debug plan, similar approach applied as I explained to you earlier on the other post
  • Does your board provide clean and stable clocking to ref design mm_clk (125MHz), ref_clk_10g (644.53MHz), ref_clk_1g (125MHz) ?
  • Does your board supply (100Mhz - 125MHz) clock to FPGA clkusr pin that's in charge to provide clocking to transceiver channel power up calibration ?
  • The ref design comes with stp1.stp debug signal_tap file. Can you trigger and capture the signal_tap debug signals for both passing and failing condition and share with me the signal_tap files ? We can then review the signal_tap files to see which status signal is failing and debug further from there
dlim
mark_lee
Hi Deshi and team
1. I use the design is build by my workmate , he is reference to the example " Arria 10 Scalable 10G Ethernet MAC+ Native PHY with IEEE1588v2 Design “;
2.My design is running 1588V2 test  success  on the demo board "Arria 10 SOC Development Kit" ;
3. MY design running "TEST_SMA_LB"  and " TEST_PHYSERIAL_LOOPBACK" test success on my board;
4. Every time running ”TEST_PHYSERIAL_LOOPBACK“,and then running "TEST_1588" 。1588TEST is success 。 THis the only  method to made 1588TEST success  now 。IF  didnot running "TEST_PHYSERIAL_LOOPBACK" before "TEST_1588" , 1588 test fail, and  the statistic log always show zero value;
5. Clock On my board is :
    (1) clock to FPGA clkusr (100Mhz );
   (2)  ref_clk_10g (644.53MHz);
   (3)  mm_clk (100MHz);
   (4) ref_clk_1g ( "no clock input "  ),
        There have no clock 125Mhz for the "ref_clk_1g"  on my  board ,  In my design did not need 1g test.
THANKS
  mark
mark_lee
Hi Deshi and team
In addition :
     I set  the "IOPLL" out2  is 125Mhz ,and use it as  the "IOPLL2 ” ref_clk_input ,  IOPLL2  output the "tod sync" and "sampling clock".
mark_lee
 Hi Deshi
  1.  When  1588 test passing  I can  trigger and capture the signal_tap debug signals;(The "1588_test_passing" file is in the enclosure)
 2 .Whe  1588 test failing  I can trigger and capture anything , as the ip core never running .
mark_lee
  Hi Deshi  and team
 I  have modify my board clock by program the chip  Si5338A, and now my board clock is :
   (3)  mm_clk (125MHz);
   (4) ref_clk_1g ( 125MHz );
  but the 1588 test is never improve
mark_lee
Hi Deshi and team
1. I had run the 1588 test project on my board with Optical fiber between 0 port and 1 port , when I run Signal Tap to get 0 port phy interface signal , I get an abnormal signal , the phy is being calibrated:
  Under these circumstances,running  1588_TEST  ,  Fail
2.   Every time after running ”TEST_PHYSERIAL_LOOPBACK 1 10G 5000“ , The  Signal Tap  get an normal signal about 0 port phy interface :
  Under these circumstances,running  1588_TEST  ,  succes
Deshi_Intel
Hi Mark,
Pls use the original working ref design without design modification. Just change the FPGA OPN and pin location to match your board only.
  • Once getting the design to work then only feel free to modify the design
Let's debug your following statement first
  • When 1588 test failing I can't trigger and capture anything , as the ip core never running
Can you share with me the signal_tap screenshot/file when the 1588 test is failing ?
  • I want to know what's the exact signal condition that you see from signal_tap in test failed condition.
Let me explain. Which scenario that you are facing here ?
  • Scenario A :
    • Signal_tap is clocked by "xgmii_clk_312_5". Once the xgmii clock presented on your board, signal_tap should start capture something (be it good or bad signal status) if you set the signal_tap trigger condition to capture everything xx. Don't set trigger condition like trigger on rising edge or faling edge
    • The only reason signal_tap will stop working is there is no clock on xgmii_clk_312_5. Signal_tap will complain "waiting for clock". Are you seeing scenario A ?
    • No clock could be due to your board stop supplying input clock to FPGA or FPGA IOPLL loose lock or your design is stuck in reset. Then you can check further from here
  • Scenarion B :
    • Signal_tap detected "xgmii_clk_312_5" and start capturing data.
    • But you set signal_tap trigger condition on some signal and the signal didn't trigger causing nothing capture on your signal_tap because it's still waiting for signal trigger.
    • Pls set the signal_tap trigger condition to capture everything xx. Don't set trigger condition like trigger on rising edge or faling edge
    • Then we see what's signal status result on the signal_tap
dlim
mark_lee
Hi Deshi
  I  facing  “Scenarion B” ;
mark_lee
Hi Deshi
the STP is  in the appendix,pls check up
Deshi_Intel
SIgnal_Tap result comparison between ref design doc (page 14) vs customer 1588_test_passed result 
Deshi_Intel
HI Mark,
May I know
  • stp_1588_TEST_success.stp = 1588 test passed result ?
  • stp_1588_TEST_fail.stp = 1588 test failed result ?
The reason I asked is due to I am seeing weird result when compared to golden reference signal_tap result from ref design doc (page 14). Attached is the result comparison that you can check it out yourself.
I suspect is either
  • (A) Something is still wrong with your board or system reset control on 1588 ref design "channel_reset_n" and "master_reset_n" ports
  • Or (B) your signal_tap result is capturing the system test run at the wrong time (like before the system is stable or after test run completed)
We now know that signal_tap is working on your board. You can then play with signal_tap trigger feature to try detect following expected signal behaviour
  • For instance, your signal_tap result shown transceiver channel is still stuck in reset and ready signal haven't asserted high
  • both ch0 and ch1 rx_islockedtodata signal doesn't assert high which means Rx channel CDR doesn't detect correct 10G data and lock yet
  • both ch0 and ch1 rx_enh_blk_lock signal doesn't assert high as well which highly due to CDR is still loose lock ?
  • ch0 link_fault status signal also asserted high which is bad
Pls try play around with trigger function and re-capture signal_tap result for both passing and failing cases then we can compared the result again.
  • You can do so yourself to compare with page 14 expected signal_tap result in parallel
  • Then we can exchange debug opinion to discuss further
Deshi
mark_lee
Hi Deshi
  • stp_1588_TEST_success.stp = 1588 test passed result ?    YES
  • stp_1588_TEST_fail.stp = 1588 test failed result ?               YES
mark_lee
Hi Deshi and team
       I  have try to make 1588V2 channel 0  loopback to channel1  on the chip without Optical module。My  code is:
" assign  rx_serial_data[0]  = tx_serial_data[1] ;
 assign  rx_serial_data[1]  = tx_serial_data[0] ;”
     then  compilation,  I get error about this  :
Error(11654): Output port "VOP" of "HSSI_PMA_TX_BUF" cannot connect to HSSI port "RX_P_BIDIR_IN" of "HSSI_PMA_TX_BUF" for atom "altera_eth_multi_channel_1588_inst|CHANNEL[1].altera_eth_channel_1588_inst|phy|xcvr_10gkr_a10_0|CHANNEL|DATAPATH_10G.NATIVE_PHY_10G_1588_644_LS.native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_tx_buf.inst_twentynm_hssi_pma_tx_buf".
Error(11654): Output port "VOP" of "HSSI_PMA_TX_BUF" cannot connect to HSSI port "RXP" of "HSSI_PMA_RX_BUF" for atom "altera_eth_multi_channel_1588_inst|CHANNEL[1].altera_eth_channel_1588_inst|phy|xcvr_10gkr_a10_0|CHANNEL|DATAPATH_10G.NATIVE_PHY_10G_1588_644_LS.native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_rx_buf.inst_twentynm_hssi_pma_rx_buf".
Error(11654): Output port "VOP" of "HSSI_PMA_TX_BUF" cannot connect to HSSI port "RXP" of "HSSI_PMA_CDR_PLL" for atom "altera_eth_multi_channel_1588_inst|CHANNEL[1].altera_eth_channel_1588_inst|phy|xcvr_10gkr_a10_0|CHANNEL|DATAPATH_10G.NATIVE_PHY_10G_1588_644_LS.native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_channel_pll.inst_twentynm_hssi_pma_channel_pll".
Error(11654): Output port "VOP" of "HSSI_PMA_TX_BUF" cannot connect to HSSI port "RXP" of "HSSI_PMA_CDR_PLL" for atom "altera_eth_multi_channel_1588_inst|CHANNEL[0].altera_eth_channel_1588_inst|phy|xcvr_10gkr_a10_0|CHANNEL|DATAPATH_10G.NATIVE_PHY_10G_1588_644_LS.native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|native_10g_1588_644_ls_inst|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_channel_pll.inst_twentynm_hssi_pma_channel_pll".
Error(11654)
 HOW  can I make channel 0 loopback to channel 1  on the chip?
thanks a lot !
Deshi_Intel
  1. We don't support FPGA internal loopback from one transceiver channel to another transceiver channel. That's why you get design compilation error.
  • We only support FPGA internal loopback within the same transceiver channel from Tx channel back to Rx channel
Just would like to follow up with you - did you have a chance to play around with different signal_tap triggering setup to observe different signal_tap result between passing and failing case ?
  • Any latest debug update to share with me ?
dlim
