Programmable Devices
21591 Discussions
Read from MAX II via JTAG
Dear all
I want read some data (power analysis) from MAX II CPLD via JTAG in "Altera EP4SGX230KF40C".
How can I read this data?
--- Quote Start ---
I want read some data (power analysis) from MAX II CPLD via JTAG in "Altera EP4SGX230KF40C".How can I read this data?
--- Quote End ---
What board are you referring to?
The MAX II CPLD is too small to implement the JTAG-to-Avalon-MM bridge (I've tried), so it will most likely be using an SLD_VIRTUAL_JTAG component, which means its access method is totally custom. You'd need to use either a power monitoring GUI supplied by the board vendor, or read whatever code was used to implement the MAX II CPLD.
Cheers,
Dave
