Programmable Devices
21611 讨论
Reading INIT_DONE internally
SBuhr
新手
801 次查看
I noticed that the user logic already starts running before INIT_DONE is asserted (about 1 us). But for example the AS_DATA Pins are controlled by user logic only after INIT_DONE was asserted.
So for using the SPI-Interface (/AS_DATA Pins) I have to wait until INIT_DONE is asserted.
Is there a way to check INIT_DONE internally? (as the pcb is already routed...)
I´m using Cyclone V GX 5.
0 项奖励
2 回复数
NurAiman_M_Intel
726 次查看
Thank you for contacting Intel community.
Sorry but there is no way to access INIT_DONE internally. Please refer to our KDB and pin connection guidelines:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03262010_335.html
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
Thank you.
Aiman
0 项奖励
SBuhr
新手
726 次查看
OK, thanks for the information + link! Regards, Simon
0 项奖励
回复
