21608 Discussions
Registering partition boundaries and reducing combinatorial logic
I have a module dac that is instantiated inside of module registers. The module instance dac drives pins dac_data_bus[11:0] at the top level. I am receiving TimeQuest recommendations to "register the partition boundaries for the path" and "reduce the levels of combinatorial logic."
As I understand it, reduction in the levels of combinatorial logic is to pipeline an operation.
Both dac and registers are driven by the same clock.
Is there a general design method that I can use to register partition boundaries and reduce combinatorial logic? What does this recommendation imply, and how do I fix it?
Here is the TimeQuest output:
Register the partition boundaries for the path from registers:registe...|dac_data_bus[0] (http://about<strong></strong>:blank#) to dac_data_bus[0] [hide details] (http://about<strong></strong>:blank#
  • issue: cross-partition paths (rdb:cross-partition%20paths)
  • to: dac_data_bus
  • timequest analysis: }%20-to%20{dac_data_bus
  • partitions that should be merged:
  • hard_block:auto_generated_inst -> Top
&#9733;&#9733;&#9733;Reduce the levels of combinational logic for the path from registers:registe...|dac_data_bus[1] (http://about<strong></strong>:blank#) to dac_data_bus[1] [hide details] (http://about<strong></strong>:blank#
  • issue: long combinational path (rdb:long%20combinational%20path)
  • to: dac_data_bus
  • extra levels of combinational logic:
  • 2
&#9733;&#9733;&#9733;Reduce the levels of combinational logic for the path from registers:registe...|dac_data_bus[0] (http://about<strong></strong>:blank#) to dac_data_bus[0] [hide details] (http://about<strong></strong>:blank#
  • to: dac_data_bus
  • 2
It appears that this can be fixed by updating the SDC file to use multicycle constraints where a delay is added. I updated the SDC file and this seemed to work well.
set_multicycle_path -from }] -to }] -setup 4 set_multicycle_path -from }] -to }] -hold 1
