Return Codes
How to use return codes when programming the device by using the following command (included in the tcl-script):
quartus_pgm --mode=as --cable=USB-Blaster --operation=pv\;file_name.pof
Quartus II command-line executables exit with the one of the following return codes.
Return Code Description
0 Execution was successful
2 Execution failed due to an internal error
3 Execution failed due to user error(s)
4 Execution was stopped by the user
So, what kind of script (.tcl) should I write, so that some return code is returned after programming?
Answer swiped from http://www.linuxquestions.org/questions/programming-9/just-wonder-how-to-get-exit-status-of-pragram-in-tcl-code-645406/
--- Quote Start ---
quote from activetcl 8.5.2.0 help pages
Code:
To execute a program that can return a non-zero result, you should wrap the call to exec in catch and check the contents of the -errorcode return option if you have an error:
set status 0 if {} { set details if { eq "CHILDSTATUS"} { set status } else { # Some kind of unexpected failure } }
quote from man n exec
Code:
To execute a program that can return a non-zero result, you should wrap the call to exec in catch and check |
what the contents of the global errorCode variable is if you have an error:
set status 0 if {} { if { eq "CHILDSTATUS"} { set status } else { # Some kind of unexpected failure } }
--- Quote End ---
