Hi folks,
I have a problem when running hello_world.c NIOS II 9.1 associated with a project created with SOPC Builder and particularly when performing I reports a problem... " Downloading Elf Process failed " can anybody help me? thanks in advance! In window " Console " appears: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Initializing CPU cache (if present) OK Downloading 00800000 ( 0%) Downloaded 54KB in 0.9s (60.0KB/s) Verifying 00800000 ( 0%) Verify failed between address 0x800000 and 0x80D51F Leaving target processor pausedLink Copied
you didn't tell what target platform you use.
i assume that you have external memory at adr 0x00800000 if yes you use external memory, have you tried to run from internal memory ? do you have timing violations ? do you use SDRam ? if yes, what about the sdram clock phase shift ?
