Hallo all,
Could anybody please share the SDC Command for setting clock latency for a "specific target clock". I am unable to find the correct SDC Command. -6.109(Setup Slack) ; APP-FPGA_Application_Logic:inst1|FilamentControl:inst30|PWM_Gen:inst1|\PWMControl:v_pulse_count_nom[0] ; APP-FPGA_Application_Logic:inst1|FilamentControl:inst30|PWM_Gen:inst1|\PWMControl:v_updatePWMvalue ; 150Mhz_Osc_Clock ; 150Mhz_Osc_Clock ; 6.666 ; 0.369 ; 13.145 ; I have a negative setup slack for a 150MHz clock in this path and I thought setting up a clock latency might constrain this. Any suggestions? Thank you!- Tags:
- timing
