21615 Discussions
SDC syntax for declaring generated clocks
Below, I have pasted a module that i have created. Now, i want to declare the outputs of this module as clocks in the SDC constraint file.
entity CLKCTRL is
Port ( -- Clock
CLK : in std_logic;
-- Reset
RESZ : in std_logic;
-- System Bus Clock Divider Value
BUSDIV : in std_logic_vector(1 downto 0);
-- Output 0 Clock Divider Value
O0DIV : in std_logic_vector(5 downto 0);
-- Output 1 Clock Divider Value
O1DIV : in std_logic_vector(5 downto 0);
-- System Clock
HCLK : out std_logic;
-- Output 0 Clock
O0CLK : out std_logic;
-- Output 0 Inverted Clock
O0CLKZ : out std_logic;
-- Output 1 Clock
O1CLK : out std_logic;
-- Output 1 Inverted Clock
O1CLKZ : out std_logic);
end CLKCTRL;
architecture Behavioral of CLKCTRL is
-- System Clock Counter
signal count_HCLK : std_logic_vector(1 downto 0);
-- Output 0 Clock Counter
signal count_O0CLK : std_logic_vector(5 downto 0);
-- Output 1 Clock Counter
signal count_O1CLK : std_logic_vector(5 downto 0);
-- System Clock
signal s_HCLK : std_logic;
-- Output 0 Clock
signal s_O0CLK : std_logic;
-- Output 1 Clock
signal s_O1CLK : std_logic;
begin
-- Based on the Value of BUSDIV
-- System Clock is selected
HCLK <= CLK when BUSDIV = "00" else
s_HCLK;
-- Based on the Value of O0DIV
-- Output 0 Clock is selected
O0CLK <= CLK when O0DIV = "000000" else
s_O0CLK;
-- Output 0 Inverted Clock is selected
O0CLKZ <= not CLK when O0DIV = "000000" else
not s_O0CLK;
-- Based on the Value of O1DIV
-- Output 1 Clock is selected
O1CLK <= CLK when O1DIV = "000000" else
s_O1CLK;
-- Output 1 Inverted Clock is selected
O1CLKZ <= not CLK when O1DIV = "000000" else
not s_O1CLK;
p_1: process(RESZ, CLK)
begin
if RESZ = '0' then
count_HCLK <= (others => '0');
count_O0CLK <= (others => '0');
count_O1CLK <= (others => '0');
s_HCLK <= '0';
s_O0CLK <= '0';
s_O1CLK <= '0';
elsif CLK'event and CLK = '1' then
-- Clock Generation for System Clock
if count_HCLK >= conv_std_logic_vector(((conv_integer(BUSDIV)+1)/2),2) then
if count_HCLK = BUSDIV then
else
count_HCLK <= count_HCLK + 1;
end if;
s_HCLK <= '1';
else
s_HCLK <= '0';
end if;
-- Clock Generation for Output 0 Clock
if count_O0CLK >= conv_std_logic_vector(((conv_integer(O0DIV)+1)/2),6) then
if count_O0CLK = O0DIV then
else
count_O0CLK <= count_O0CLK + 1;
end if;
s_O0CLK <= '1';
else
s_O0CLK <= '0';
end if;
-- Clock Generation for Output 1 Clock
if count_O1CLK >= conv_std_logic_Vector(((conv_integer(O1DIV)+1)/2),6) then
if count_O1CLK = O1DIV then
else
count_O1CLK <= count_O1CLK + 1;
end if;
s_O1CLK <= '1';
else
s_O1CLK <= '0';
end if;
end if;
end process p_1;
end Behavioral;
Anil.
The following documents will help you set up time constrants in SDC for you design
http://www.altera.com/literature/hb/qts/ug_tq_tutorial.pdf - TimeQuest Analyzer Tutorial
http://www.altera.com/literature/hb/qts/qts_qii53018.pdf - The Quartus II TimeQuest Timing Analyzer
Cheers
Rob Morley
Be careful about driving clocks with logic resources. Something like a clock divider is better done with a PLL if you have a PLL available or with a clock enable.
I have a post at http://www.alteraforum.com/forum/showthread.php?t=453&highlight=clock+enable with some considerations if you do use logic resources to do the clock division.
Hi Brad,
Thanks for your reply. I have checked your post. But i have some problems. I cannot use PLL's. I just have a clock and i need to divide this directly. Now, how can i use a clock enable to get a divide by 1 or 2 or n clock , with approx 50% duty cycle.
if this not possible. Let me know, how i can assign this divided clock to a global assignment. Because this doesn't exist on my top level entity for the FPGA.
Anil.
To do a divide by n, you create a signal that pulses every nth clock cycle (the signal is asserted for one full clock cycle out of every n clock cycles). That signal is used as the clock enable. The registers running at the slower speed with that enable are clocked by the full-speed clock signal; the enable gives the same effect as using a slower clock. You can use multicycle exceptions in TimeQuest to say that any path between clock-enabled registers is allowed n clock cycles for setup.
The Quartus II version 7.1 handbook shows how to describe the clock enable in HDL. Volume 1, Section II, Chapter 6, Example 6-31 has a VHDL example with a clock enable together with other control signals that you can omit if you don't need them. You need the nested "if" that describes the enable inside the "if" that detects the clock edge.
Here's an example of a way to create the multicycle exceptions for a divide by n (set to divide by 4 in the example). This example uses get_fanouts to apply a single pair of setup and hold exceptions to all paths where the source and destination registers both use the same clock enable. The set_multicycle_path -from and -to fields each contain the full set of registers using the clock enable. TimeQuest will apply the multicycle exceptions to all the paths that actually exist between all possible pairings of these registers. When you use the clock enable resource in silicon, it is OK if the new data actually arrives at the destination sooner than the n clock cycles. The multicycle hold of n-1 tells TimeQuest that the old data does not have to be held during the clock cycles when the clock enable is deasserted.
set all_enabled_registers ] set clock_enable_divide_by_n 4 set_multicycle_path -setup $clock_enable_divide_by_n -from $all_enabled_registers -to $all_enabled_registers set_multicycle_path -hold -from $all_enabled_registers -to $all_enabled_registers
