SFL image
名誉分销商 II
3,563 次查看
hi all,
i found that serial flash loader allows epcsx to be configured through jtag, i would like to know how to instantiate the sfl image to the user design using sfl megafunction
0 项奖励
7 回复数
名誉分销商 II
1,577 次查看
Simply include the SFL instance to your top level design.
0 项奖励
名誉分销商 II
1,577 次查看
but how to control the ASMI access granted and ASMI access request signals of the mega function
0 项奖励
名誉分销商 II
1,577 次查看
You don't them, unless you don't have other connections of your design to the AS memory. A typical instantiation looks like this:
sfl_inst : sfl PORT MAP ( noe_in => '0' );
0 项奖励
名誉分销商 II
1,577 次查看
how should be the ASinterface connections and nCONFIG connection to fpga while configuring EPCSx via SFL image
0 项奖励
名誉分销商 II
1,577 次查看
It's all in the device manuals, e.g. figure 10–30. programming serial configuration devices in-system using the jtag interface for Cyclone III.
0 项奖励
名誉分销商 II
1,577 次查看
I have ASMI connections to EPCS.Int his case,how do I connect(instantiate) SFL?
sfl_inst : SFL PORT MAP (
asdo_in =>
asmi_access_granted =>
dclk_in =>
ncso_in =>
noe_in =>
asmi_access_request =>
data0_out =>
0 项奖励
名誉分销商 II
1,577 次查看
I have ASMI block in my design.In this case,how do I connect other pins?
Isee following errors when I disable Share ASMI interface option.
Error: Pins ALTERA_DCLK both have the SPI-related DCLK Pin assignment, but only one pin can have this assignment
Error: Pins ALTERA_SCE both have the SPI-related SCE Pin assignment, but only one pin can have this assignment
Error: Pins ALTERA_SDO both have the SPI-related SDO Pin assignment, but only one pin can have this assignment
Error: Pins ALTERA_DATA0 and ALTERA_DATA0 both have the SPI-related Data[0] Pin assignment, but only one pin can have this assignment
0 项奖励
回复
