Programmable Devices
21593 Discussions
SFP+ transceiver modules compatible with Stratix V GX board
Contributeur émérite II
1 133 Visites
I need to buy an SFP+ transceiver module with optical interface and I was just wondering are there any compatibility issues with using any module with an Altera Stratix V SI development kit board? I need to have a 10G data transmission at 1550nm, so probably a LR or ER module has to be used and not the ones operating at 850nm and 1310nm. Has someone used an SFP+ at 1550nm and if so, which module did you use? I was looking at Finisar's modules like:
https://www.finisar.com/optical-transceivers/ftlx1672d3bcl
https://www.finisar.com/optical-transceivers/ftlx1672d3bnl
https://www.finisar.com/optical-transceivers/ftlx1672d3btl
It would be great if you could give me a reference to an already tested compatible module...
0 Compliments
0 Réponses
Répondre
