21611 Discussions
SOPC Builder Tutorial
Now I'm working with SOPC Builder tutorial and suddenly an error appeared during type the given code (lights.v). I already Add the files and all the *.v files produced by the SOPC Builder to the Quartus II project. Below is the error appeared when I run the codes.
Error (10170): Verilog HDL syntax error at unnamed_inst.v(3) near text "("; expecting ";"
Error (10839): Verilog HDL error at unnamed_inst.v(2): declaring global objects is a SystemVerilog feature
I hope you guys can highlight what is the problem and how to solve it.
Thank you so much.
What is "unnamed_inst.v"? Perhaps you should post the code the error is pointing to for us to look at...
Thank you so much. I already fix that problem. but now there is another error appeared during generate the c code. when I try to build the lights.c there an error appeared
collect2: ld returned 1 exit status
make: *** [lights.elf] Error 1
Why does this error appeared actually?
Just a hunch. Try running NIOS as administrator..
Really appreciate for your reply. But its weird because i dont have an option for run as adminstrator in my 'run as' menu.
I'm not sure this is privileges related.
What hardware platform are you running this on? Do you have enough memory for the application?
Alex
