21615 Discussions
SPLD ATF16V8C coding using WinCUPL
I have learnt CUPL recently. I have written a pld code for my application. And here is the code:
Name US_Timing_IN ;
PartNo ATF16V8C ;
Date 11/24/2011 ;
Revision 01 ;
Designer Deepika ;
Company XYZ ;
Assembly None ;
Location ;
Device virtual ;
/* *************** INPUT PINS *********************/
PIN 1 = res ; /* */
PIN 2 = mhz ; /* */
PIN 3 = ad1 ; /* */
PIN 4 = ad2 ; /* */
PIN 5 = ad7 ; /* */
PIN 6 = ad8 ; /* */
PIN 7 = ad3 ; /* */
PIN 8 = ad4 ; /* */
PIN 9 = ad6 ; /* */
PIN 10 = gnd ; /* */
PIN 11 = ad5 ; /* */
PIN 13 = test ; /* */
PIN 15 = b ; /* */
PIN 16 = a ; /* */
PIN 18 = ad9 ; /* */
PIN 20 = vcc ; /* */
/* *************** OUTPUT PINS *********************/
PIN 12 = tg ; /* */
PIN 14 = dg ; /* */
PIN 17 = cw ; /* */
PIN 19 = reset ; /* */
/* *************** Reduced equations **************/
tg = !(ad4 & !ad7 & !ad8 & !ad9 & test
# ad5 & !ad7 & !ad8 & !ad9 & test
# !ad6 & ad7 & !ad8 & !ad9 & test
# ad2 & !ad4 & !ad5 & !ad8 & !ad9 & test
# !ad3 & !ad5 & ad7 & !ad8 & !ad9 & test
# ad3 & !ad4 & !ad5 & !ad8 & !ad9 & test
# !ad4 & !ad5 & ad6 & !ad8 & !ad9 & test);
dg = !(ad9# !test# !ad8# !ad6 & !ad7);
reset = !(ad6 & ad9 & mhz & res
# ad7 & ad9 & mhz & res
# ad8 & ad9 & mhz & res
# ad1 & ad2 & ad3 & ad4 & ad5 & ad9 & mhz & res);
cw = !(!a# !b# !mhz);
I have selected the correct device from the list, also i have unchecked Device in file option.
But when i try to compile it the compiler crashes, please let what is the problem with the code and settings.
Waiting for the help. Thank you,
Deepika
