Hi, I'm University student. I must study the possibility to inteface two or more DDR2 to STRATIXII. I want use DDR2-667 so I must use only DLL based interface. I read STRATIXII handbook but I don't undestand if it's possibile to use 4 DDR2-667...Help me please...
Thanks everybodyLink Copied
it is. DDR2 667 is a 333MHz interface, which is supported in faster speed grade devices in stratix ii & iii.
--dalon- Mark as New
Whether you can use 4 interfaces would be dependent upon how wide each interface is... I believe you can get away with up to 4 - 36bit interfaces...
2 cents, -Chris- Mark as New
I understand that I can interface 4 DDR2 (width x16) with DLL interface type... Do you think like me? thanks- Mark as New
I suggest you can use DDR2 SDRAM SODIMM, which is cheap and easy to control. For example:MT4HTF1664HY-667
