21615 Discussions
STRATIX 2 GX: CRU output frequency
I'm using the STRATIX 2 GX and the ALT2GXB. So I will transmit and receive the data with 6250 Mbps. I programm the Stratix 2 GX with Quartus 8.0.
This are my configuration:
Protocol: Basic Double Width Mode
Operation Mode: Receiver and Transmitter
Channel: 1
Channel Width: 32 bit
Input Clock: 156.25 Mhz
Data rate: 6250 Mbps
If I compile my project, the "Analysis & Synthesis" part runs error free. But after that, the fitter gives an error.
This is the error message:
CRU output frequency 2500 Mhz (datarate 6250.0Mbps) of the receiver PLL of GX receiver channel atom "alt2gxb0:inst|alt2gxb:alt2gxb......" must be in the frequency range of 499.8 Mhz (datarate 1000Mbps) to 2127.7 Mhz (datarate 4255.3 Mbps).
Do someone know, how I can eliminate this error??
If I put the data rate to 3906.25 Mhz the project runs without a problem.
Because of this problem, I have read the handbook of the Stratix 2 GX again and I think on page 2-62 stands something about this problem. But it doesn't help me.
I hope someone in the forum can help me.
Many Thanks
yknarf
I have found the answer of my problem.
The answer of the problem is, that only a Startix II GX with a speed grad of 3 can suport High speed transceivers up to 6.375Gbps. When you use an other speed grade the CRU recovers a clock, which is too fast for the PLD.
