Programmable Devices
21602 Discussions
Serializing Avalon-ST over XCVR for FPGA-to-FPGA Transmission
I would like to know what options are available for serializing Avalon-ST video data over high-speed XCVR for tranmission between two FPGAs with lowest latency? I have a set of HD resolution video interfaces (VGA, DVI, SDI, etc.) available on one FPGA but I want make them also available to a 2nd FPGA. I assume by using XCVR I can reduce the FPGA-to-FPGA pincount while maintaining the data bandwidth. But I'm not sure what XCVR mode I should use.
I am open to alternate suggestions as well.
Thanks in advance!
The mode of XCVR to use will be depending on your target data rate, interface width, refclk and etc. If you are looking for a ready-make solution, you can try to look into Altera IP cores ie SDI IP and etc to see if can find one that suit you.
You'll want to use a mode that incorporates the 8/10B encoder. This makes recovering bytes out of the serial data stream trivial, and supports mismatched data rates through the use of IDLE codes.
I have not used it, but I am pretty sure the SerialLite core is for light-weight chip-to-chip communications. Xilinx have a similar protocol called Aurora. I don't know how compatible these two protocols are. Perhaps someone who has used them can comment.
You should "do the math" to determine what sort of bit-rate you require, what sort of lane rate you think your PCB can handle, and hence how many SERDES lanes you will need.
Cheers,
Dave
Hi mbp2014,
You can also visit the Altera wiki page, look for transceiver category for the PHY level design example. They will serve as a good start with the Altera transceivers.
